What should I plant?
/ What should I plant? #1
City Farmer
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hi all. I've been looking for some property for a while now. I settled on 24 acres, 17 open with beans planted now and 7 acres of woods.
In the spring, I'd like to plant something myself to keep my agricultural tax designation. The farmer that's currently planting the 17 acres only pays $400, he said that's the going rate for 17 acres. For $400 it's more of a hassle to have him in there. I'd like to cut the driveway, put the pond, mini orchard, clear/move some over grown hedge rows, plant some trees and prep the area for a barn. I probably won't start building a house for a couple of years at the earliest.
I have 3 old tractors, a Ford 3000, 4400 TLB, Case 831C and a Case 350B dozer. My Implements are, 2 bottom plow, 60" KK tiller and a 12' wheel disc. I'll buy/trade for a planter or whatever else I need to harvest. I was thinking hay but if someone else has a better idea, I'm open to anything.
/ What should I plant? #2
I would check with other farmers. Seems to me $400 for 17 acres is dirt cheap. Here in Kansas $50 + an acre is more like it and I was astounded that other regions of the country were receiving 3-4x that for cash rent.
/ What should I plant? #3
That is cheap rent. Are they putting back into the ground and maintaining such as cutting trees back or tile?
He's not doing any improvements, the run off ditches have trees growing in them and the main trail is all rutted up. Instead of putting in a culvert, he just pushed dirt into the run off ditch to get between the fields. I don't know if he's putting anything back into the ground but I doubt it. It's time for him to go, I think I'll try hay. I can tell the county its planted even if I don't harvest it.
/ What should I plant? #5
In what county is your property located?
You can look up average county rental rates here: USDA/NASS QuickStats Ad-hoc Query Tool. Keep in mind that rental rates vary within county depending on soil productivity, proximity to potential renters' operations, etc. These rates also vary over time with crop prices.
Depending on MI's land-use assessment requirements, you may have to provide copies of a Schedule F or E, or Form 4835 to document farm income. Most counties don't take your word for it when it comes to qualifying for ag, use assessment.
Steve
/ What should I plant? #6
Find out what impact in actual dollars the agricultural designation saves you. Remember, taking the deduction on land you own and farm requires claiming profits and loses on your income taxes. Renting it out absolves you from these requirements.
Until you build a house or barn, I can't imagine the tax savings would amount to very much and certainly wouldn't offset the hassle of a potential tax audit.
When does your current agricultural exemption and contract expire? Many states require a signed rental contract or affidavit from you regarding how many acres are under the exemption and may be valid for several years.
Enjoy your new property and good luck!
/ What should I plant? #7
You have to declare rental income when filing your federal income taxes.
Steve
/ What should I plant? #9
In Florida you don't have to show income to be declared a "bona-fide farm". I would say 17 acres of planted pines.
In NC, you can qualify for forestry-use assessment if you are following a forestry management plan prepared by a forester. The plan has to cover a minimum of 20 contiguous acres.
Steve
/ What should I plant? #10
It sounds like anything, from doing nothing to whatever, would be an improvement. I agree he has to go.
/ What should I plant? #11
You need to contact a county agricultural agent and get his/her input.
Florida has "Green Belt" classification for ag property.
Thanks everyone, I have a lot to look in to and and some real good places to start. I'll keep the thread active while I look in to everything.
/ What should I plant? #13
Sound like a ground raper or just figured he would be out so he didn't care. He made a lot of money off of depriving your land.
/ What should I plant? #14
Yikes, that's too bad. I'd put him on the next train, errr tractor outta there.
/ What should I plant? #15
Yikes! Agreed that the renter needs to leave. There are good renters out there, but this guy doesn't sound like one. Our renter has been fantastic! He's graded ditches, maintained the culverts, keeps the fields looking like a million bucks, and even removed a spongy grove of junk trees that has been creating problems; He's even voluntarily raised the rental price.
If you want to plant something, but not have to harvest it, you could plant buckwheat. It'll choke out the other weeds and put nitrogen back into the soil. Mow it down, plow or disc it in, and plant something else when it's about done. The mowed stuff will put more nitrogen as well as good organic matter back into the soil.
Joe
/ What should I plant? #16
Instead of booting him, tell hm the rent is 150 pr acre (going rate here in Michigan for row cropping) and see what he says before giving him the heave-ho..... A bird in the hand is better than a sharp stick.....
2002 CHEVROLET 3500 FLATBED TRUCK (A64278)
2002 CHEVROLET...
PALLET OF JOHN DEERE WEIGHTS (A64278)
PALLET OF JOHN...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
Chevrolet Tahoe SUV (A64557)
Chevrolet Tahoe...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
