FEL Tree Trimmer
/ FEL Tree Trimmer #1
XxLT250RxX
NW Alabama
I am interested in building a tree trimmer like the one in the video. I would probably use a single 24" blade similar to the video or maybe two or three smaller blades mounted vertical. The company appears to be out of business. Any ideas on what the specifications on the hydraulic motor might have been?
/ FEL Tree Trimmer #2
A 3 cu in hyd motor using 10 GPM and 2500 psi, will run at 770 rpm and develop about 1194 in of torque.
If you go to smaller cu in motor, the speed increases, and the torque decreases.
/ FEL Tree Trimmer #3
Hate to be a spoilsport for a good project,,,,,,but I do exactly what that that guy's doing all the time, with a string-trimmer that has a skilsaw blade on it. I can reach higher, reach lower, cut many more angles, cut each branch in a more sensible way, including flush-cut at ground level, and cut much faster. And not leave any eye-pokers.:shocked:
I can also reduce a cut branch to 1-foot chunks in seconds, and not have to pick it up. TING TING TING TING. Done. I tried a 10" carbide blade, it was heavy, took awhile to spool up and seemed very dangerous, I like the 7 1/4" skilsaw size. Plus I have a stack of old skilsaw blades, so it's almost zero cost.
:cool:
More description on post 56 of this other thread
I recently bought a new echo PAS266 PAS-266callouts.jpg with the quick-attach system - and a 3 foot 'extension', I can cut 11 feet high. I have the chainsaw attachment too, for bigger stuff. The skilsaw is much faster and much lighter than the chainsaw on anything less than 2". Out on the end of a 6 foot (or 9 foot) pole the chainsaw weight makes a huge difference, as well as the speed, how long you have to hold position.
Having both is good, especially if you get one stuck you can unhook and cut it out with the other. I find the skilsaw blade to be far easier to use, and can work many more hours than with the chainsaw attachment (due to weight and cut speed). Plus you can cut bushes flush at ground level with the skilsaw.
Here's how I attached the skilsaw blade. Don't even bother testing echo's 'brush blade', you need carbide. You just touch the branch, and TING, TING TING it's gone.
Sorry for going off-topic, depends if you want to build something, or cut brush. If you want to cut brush, I'm certain the string trimmer option is better.
/ FEL Tree Trimmer #5
My $0.02
If you're gonna trim trees, do it the right way. That video was painful to watch. Make flush cuts when possible/practical. Do it during late winter or very early spring. Not Fall or early winter.
Cutting like that may result in the trees pushing even more growth where it is not wanted.
Also, not cutting back to the trunk or to a primary branch you will most definitely end up with more, small prunings, resulting in even more clean up work.
And may I suggest wearing a proper forestry helmet with face shield?
Happy tree trimming!
/ FEL Tree Trimmer #6
/ FEL Tree Trimmer #7
I have one of those. They sized the cylinder big enough to cut anything that will fit within the jaws. It's way overkill for small stuff though because the cycle time on that 5 inch (or so) diameter cylinder is slow.
What machine are you using it on?
I am thinking about getting one, the V417 has 22 gpm, so might not be too bad.
/ FEL Tree Trimmer #9
Yep, carbon table saw blade on mine as well...awesome and talk about building forearm strength. I will however share. I have seee a bucket with a receiver tube on both sides of the bucket. this allowed the user to mount a hitch tube 3 ft long. The end of the tube has to sections of 3/4 metal he had milled at a 50degree angle. The same set up a seatbelt cutter works. They pulled up, snag said branch and backed up or let the FEL down and slice the branch was off nice and clean..largest I saw was 3'. Wish I had a pic of it.
:cool:
I recently bought a new echo PAS266 View attachment 396562 with the quick-attach system - and a 3 foot 'extension', I can cut 11 feet high. I have the chainsaw attachment too, for bigger stuff. The skilsaw is much faster and much lighter than the chainsaw on anything less than 2". Out on the end of a 6 foot (or 9 foot) pole the chainsaw weight makes a huge difference, as well as the speed, how long you have to hold position.
View attachment 396557 View attachment 396558 View attachment 396559
View attachment 396560 View attachment 396561
/ FEL Tree Trimmer
I made something similar. It is two "knives" mounted to the bucket. See below. They work OK but would like to have something faster and able to cut bigger limbs.
/ FEL Tree Trimmer #11
That unshielded blade and the lack of a positive locking nut look like an accident waiting to happen.
What would happen if the blade kicks or a thin branch starts wrapping itself in the blade.
I would hope the trimmer would stop, but there would always be the danger of the blade nut coming undone and the blade flying off
in some random direction. Find a way to cotter pin the nut so it cant come undone please.
/ FEL Tree Trimmer #12
Buy a pole saw from Stihl. The thing in the video looks like more trouble than it's worth.
/ FEL Tree Trimmer #14
I use it on the Gehl tracked loader. I think it's about 18 gpm but I don't usually run full throttle.
I could also buy a smaller cylinder for it for trimming. With quick connects all around, it wouldn't take much to swap them out. I even suggested that as an option to a factory rep for the product. He dismissed it because "it only takes 4 seconds or so" to close. But that 4 seconds to close and slightly less time to open really adds up with a lot of branches.
/ FEL Tree Trimmer #15
Well Papa, I agree somewhat with the pole saw being much more effective. Stihl is about $700 I think. I think the FEL mounted saw in the video would waste a lot of time cutting branches in the wrong place. And waste a lot more time attempting to cut branches in the right place.
I have a string trimmer with a carbide 7 1/4" skilsaw on it and a string trimmer with a polesaw. Pole-chainsaws are a heavy lump on the end of a pole. You don't just "slash with it. You have to carefully place it on each branch, then hold pressure on it, all at the end of a "pole". Running a polesaw for one hour is like a chainsaw for 4 hours.
String trimmer with skilsaw is much lighter, and at least 5x faster cutting than the polesaw. You can "slash" with it, which is cut multiple branches in one swing (if that makes sense). You can also position it accurately, because it's lightweight. There is absolutely no comparison. I will cut a hundred branches with the skilsaw and maybe one will inspire me to go get the polesaw. Which I don't, It's actually easier to chip away at it with the skilsaw. And cutting at ground level with a polesaw is more strenuous, leaves punji sticks, and the chain gets in the dirt. I'll use the polesaw if branches are bigger than 2.5".
I have a lighweight string trimmer with a carbide skilsaw (echo 225), and a commercial string trimmer with a carbide skilsaw (echo PAS-266). With the 266 I have to resist the urge to "put it down" feels like twice the weight. I prefer the lightweight trimmer, gets far more work done, I'll cut for hours with the 225.
/ FEL Tree Trimmer #16
And if you are "slashing" your trees, you are making more work for yourself. In the both the cleanup of all those smaller branches and, more importantly, in the following years when you're trying to clean up all the water sprouts that are being triggered by improper pruning. Additionally, by slashing, you're creating more open wounds for pathogens to attack the tree. Clean cuts made near the collar will heal quicker, as well.
The pole saw exists for a very good reason... it's the right tool for the job.
With tree pruning, faster is not better. IMO. And yes, it does take a lot of energy to do it properly.
$0.02
/ FEL Tree Trimmer #17
I've been trying to find something similar to what I saw on that FEL bucket years ago. This is the closest I could getOrange-belt-cutter.jpg
/ FEL Tree Trimmer
Guys I am not pruning trees in my yard. I have several roads and fields that need trimmed. The limbs are sticking out into the roads and the edge of the fields and making it very difficult to bushog without getting slapped off the tractor. I appreciate all the replies and suggestions but I don't intend on spending days or weeks using a string trimmer or pole saw. I want something that will cut 3 or 4 inch limbs an do it as fast as possible. I also prefer to build it myself. I am a machinist with a complete machine shop at my disposal. I other words I need to do it as cheap as possible. I believe a saw similar to the one I posed would work but I know nothing about hydraulics. (Thanks for the help JJ) Here is what I am thinking but on a smaller scale. Any other suggestions appreciated. Again thanks to everyone for the replies.
/ FEL Tree Trimmer #19
I played with a design idea similar to the video and figured the blade would need to run several thousand RPM to cut small cedar branches without being grabby. Those fast hydraulic motors were pretty expensive compared to the more common speeds. But if you are not going with direct drive, like in this picture, maybe you could gear the blades up in speed.
Another idea to make it less grabby is grinding less rake on the teeth faces. I wouldn't mind trying a chainsaw ground that way too, for the same type of pruning. It might be pretty fast.
/ FEL Tree Trimmer #20
cutting 3" to 4" branches... and needing to deal with the branches after being cut is the issue. rotatory cutters (brush hogs = brand name) can only handle such a big limb before getting stuck and stopped by larger branches.
the old 1954, allis chalmers ca tractor with bellow mower, with muffler i am guessing around 6 to 7 feet off ground, then your head about another foot above that... call it 8 feet. a couple times a year, i go around with another person normally my mom. 1 driving the pickup truck, while the other person is in the bed of truck, using pruners and like to cut down branches. in the better areas, we just toss the trailer on as well. and cut and toss into trailer as we go. though some areas it just ends up being a pill of limbs on each side of truck, and come back for them later with empty trailer. vs getting in/out of the truck non stop dealing with branches that fall out of hand.
the truck takes a few scrapes, we take a few scrapes from the branches, but *shrugs*, just how it is.
if we need to, we will brake out a 8 or 12 foot fold up / A frame ladder. but that generally is pushing it, and the tree limb is really eerking us. other wise, mowing = another larger turn around the branch.
i am not much for running a chain saw in back of truck bed (safety), and if i did, it would be the smallest possible chain saw possible. "way to much over head work" less weight the better.
i do NOT recommend putting someone in bucket of FEL (front end loader), way to easy for the bucket to dump, and bye bye person within it. more so working with tree branches that could catch the levers / joystick. *been there done that* not with person in FEL bucket, but catching a lever/joystick.
--i am uneasy with it, but they do sell some "man lifts" style setups, that attaches to FEL's. but still just does not seem safe to me.
if you had a mini excavator or a backhoe, i think i remember seeing a couple hydraulic driven chain saw blades, that one could swap out the bucket for.
but out of all options, the tree companies most likely have best setup... the man lift / bucket trucks. what many electrical / telephone pole companies use to raise there workers up to the tops of telephone poles, or get in and cut down the trees. (from the tops down) vs just cutting tree at the ground and letting it fall over.
you might see if you could rent a bucket truck some place (not sure if that is possible?) you can rent self propelled scissor lifts / extendable man lifts / buckets with full size R1 ag tires, or R4 industrial tires on it.
i no longer remember the "thread name" maybe a year old? it was hydraulic chain saws. same basic thing as the circular saw blade in the 1st post, but with a chain saw blade.
i think someone setup a hydraulic chain saw and a wood splitter (turned the FEL bucket into a wood processor) but this was for logs already cut, not for branches.
with everything said, the hydraulic motor, the extra valve, hydraulic hoses, and the fittings. are going to run you a few hundred bucks.
i am going to say go with others with a pole saw, or circular saw on the weed whacker or like. vs trying for a tractor mounted option.
some of the "straight shaft" weed whackers / trimmers, you can buy a pole saw extension for it. pull off lower half trimmer, and snap on the pole saw extension. if you have any ponds / lakes you need to deal with (cutting banks). folks have used the "hedge trimmer" extensions. as a heavy brush / tall weed whacker. other words turning the hedge trimmers into more like a sickle mower in idea. 1 engine and a few different extensions *shrugs*
SKID STEER FORKS (A62613)
SKID STEER FORKS...
Unverferth Perfecta 3pt 20' Field Ciltivator (A64126)
Unverferth...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2016 Deere 550K (A64126)
2016 Deere 550K...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
