TRACTOR NEWBIE
/ TRACTOR NEWBIE #1
terry5449
Cypress
none
I have recently purchased 30 acres of land, mostly wooded. I have decided to buy a kubota tractor. I have already purchased a ZT ( EXMARK) for mowing approximately 4 acres. My question is which is better for my needs..a 3800DT or a MX5100. I need it for brush hogging and moving downed trees. I am also considering a grapple. At a cost of almost three grand..will I use it enough to justify the cost? I plan to do some clearing and replant in commercial pine. This is something that is big in East Texas. Thanks for any insite
/ TRACTOR NEWBIE #2
Welcome & congrats on the land purchase.
You need to prioritize your needs for your attachments. That being said I definitely recommend the grapple. You will use it for a lot more than just land clearing.
/ TRACTOR NEWBIE #3
For the size of property I would go with larger model grapple is a great piece of equipment. Need a third function valve and probably get rear remotes enjoy:cool2:
/ TRACTOR NEWBIE #5
for what your wanting id go with the mx5100.
/ TRACTOR NEWBIE
I've read that the MX5100 is a fuel hog. Any experience with one or the other?
/ TRACTOR NEWBIE #7
how are you going to handle tree stumps / root balls... that is the big question there. from 3pt hitch backhoe, mini ex (mini excavator), to tree stump grinder, (just removes what is above ground and maybe a little below), to a dozer.
your big ticket items tend to be... FEL (front end loader with general duty bucket), tractor itself, and then a 3pt hitch backhoe with a sub frame for it. getting the big ticket items all at once on same order from same dealer. the dealer may give you a bigger discount.
some folks save up projects and rent a bigger machine from time to time. for example a larger excavator vs a mini ex. to do various jobs in one wild weekend non stop running the machine. while others justify cost of having one around when ever they need it.
rotatory cutter (bush hog = name brand), are all over the place from third party manufactures. rear blades, box blades, graples, etc...
exception with above, if you want a grapel, and not enough cash up front for it, go ahead and get the 3rd function valve kit, for the FEL (front end loader), more likely save you some costs long term having dealer install it before it is delivered to you.
i would suggest AG / R1 tires. due to more likely you will be hitting a lot of mud/dirt/etc.... and industrial / R4's = you being stuck in the mud, (regardless of 4x4 / MFWD, differential lock, split left and right rear brakes)
if you are looking at possibly a electrical winch for tractor, see about getting the larger alternator if option for the tractor.
a lot of folks like TNT (top and tilt) a hyd cylinder replaces top link on 3pt hitch, and for tilt, a hyd cylinder replaces one or both of the side links / turn buckles on the 3pt hitch. if ya going for TNT, would suggest bare min of 2 to 3 rear remotes. again might be cheaper long term to have dealer installed, before it is delivered to you.
all the little options due tend to add up rather quickly, making a larger tractor out of budget vs a smaller tractor with all the extra smaller options. many of the smaller options can make many tasks quicker / easier / more professional done with out much extra fuss. smaller tractors just take longer at certain jobs. the only issue is skidding logs, the bigger and longer they are, and more hills ya gotta climb, a bigger tractor will more likely keep on going vs a smaller tractor. but you could always chop log in 2 or more chunks. to drag up and out of the woods.
/ TRACTOR NEWBIE #8
Go as big as you can afford. I have an mx5100 on my 20 acres and I love it but at times wish for more, although I do use it somewhat commercially as well.
/ TRACTOR NEWBIE #9
I haven't heard that. I believe that most modern tractors will consume about the same amount of fuel to complete a given task, regardless of the tractor's size. My little BX23 just gently sips diesel at a much lower rate than my Kioti DK50SE, but the Kioti will get the job done faster. So, in the end, I think they would both use about the same amount.
For the work you describe, I'd get the MX5100.
And you don't have to spend $3,000 on a grapple. You can get a perfectly suitable one for around $2,000. For example:
Everything Attachments Wicked Root Grapple for Compact Tractors
or
There are lots of sources for grapples. I bought a stump grapple from Wildkat Attachments and I've been very pleased with the build quality. Here's a link to their ebay store:
Wildcatattachment, skidsteer bucket items in WildcatAttachments store on eBay!
/ TRACTOR NEWBIE #10
There are many MX owners on TBN and lots of posts... generally they say it's a workhorse they really like. Can't recall anyone saying it being a fuel hog, but check the Kubota forums for yourself. The MX5100 (now MX5200) is turbocharged; the MX4700/4800) is a non-turbo version that might be bit more frugal. Most of the time, you don't need to operate this equipment wide open, where it uses the most fuel and you'd notice the difference. The extra hp would be useful for heavy brush mowing, but for non-pto chores either model would have all the power you could put to the ground.
/ TRACTOR NEWBIE #11
Terry--First find you a Kubota Dealer you like and trust, then explain to him your needs. You don't want to get a tractor and then find that it might not be big enough. If you can get the Grapple you'll never regret it. I have Grapple Envy so I'm trying to save for one and justify it with the little woman.
Charlie
/ TRACTOR NEWBIE
I have read all your posts and thank all of you. I have a test drive scheduled Saturday..if I can break away from remodeling the house.....whole 'nother story...Will keep you informed. If anyone else has any feedback on the MX series, please post.
Thanks again.
/ TRACTOR NEWBIE #13
Terry,
I purchased the MX5100, and can vouch as to it's versatility. I got the b/h 92 attached with full frame, as well as bush hog, tiller, 844 fel, 84"box blade. As for fuel comsumption, I avg 1 gal imp / hour on most tasks, between 1700 to 2100 rpm.
I am at 400 hrs now and have had no serious issues with the tractor. In my opinion, well worth it!
/ TRACTOR NEWBIE #14
I know nothing about the 3800, but I can strongly recommend the mx5100. Mine has the R4 tires and so far I've had no problems getting stuck. Without the 4x4 it would be kind of shakey, though. I'd say I average about 2 gal/hr on diesel, and that's working it pretty hard.
/ TRACTOR NEWBIE
Well I finally pulled the trigger and ended up with an MX5100. I had to pay a little more than I thought because I wanted a pre emission tractor. I used it over the weekend and loved it! I guess I can be a kid and play in the dirt! I am surprised by what I can do with it, and I'm glad I went with the bigger tractor. I am also surprised by the small amount of fuel I used.....about five gallons. I'm sitting here at work today trying to think of some "work" that needs to be done this weekend.
/ TRACTOR NEWBIE #16
Well I finally pulled the trigger and ended up with an MX5100. I had to pay a little more than I thought because I wanted a pre emission tractor.....
What do you mean you had to pay more? The tier 3 tractors (mx5100) should be quite a bit less expensive than the new tier 4 tractors.
Congrats on the new tractor btw
/ TRACTOR NEWBIE
I was looking..trying to decide what to buy. I decided I didn't want to go with a tier four, seems like more stuff to break. The MX5100 inventory dried up so that there were no deals. In September I was offered incentives not to finance. When I bought in October the local dealer didn't have any new "old" models left, so I was forced to go two hours away and pay delivery and no rebate. I still think I made the right decision . When looking to spend 30k I was going to take my time so that I wouldn't have regrets.
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
1998 KENWORTH W900L 6X4 TANDEM AXLE SLEEPER TRUCK TRACTOR (A59912)
1998 KENWORTH...
UNUSED SDLANCH SDLC2533FT 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
UNUSED INDUSTRIAS AMERICA 190-9' SCRAPE BLADE (A64280)
UNUSED INDUSTRIAS...
