Tractor Log Splitter
   / Tractor Log Splitter #1
otherguy
Member
MO
Kioti DK45SE
What are the advantages or dis-advantages of having a log splitter that can only be used on the tractor vs having a gas powered one?
Thanks
   / Tractor Log Splitter #2
Well I will start...
Don't need a tractor with a gas powered unit... thus more portable.
With a tractor you don't have to have another engine to maintain.
   / Tractor Log Splitter #3
You can't take it off site
Your brother in law can't take it off site
   / Tractor Log Splitter #4
I prefer vertical tractor mounted to save having the extra engine to keep up. I originally made mine for a 1958 JD 520 using the tractor hydraulics: Picture 264 (Small).jpg
When I sold the 520 & bought an '04 790, I had to add a control valve to the splitter & long hoses to the loader bucket connections: HPIM3027.JPG HPIM3028.JPG
I tie the joystick off to the opposite fender with a tarp strap & go to work. This isn't fast, but neither am I & I work alone. By the time I get the splits stacked, it's up & ready for the next one. As for hours on the tractor, I put around 100 hours/year on it, the few hours spent on the splitter aren't going to add up very fast! ~~ Lowell
   / Tractor Log Splitter #5
Advantages to using a 3pt log splitter:
as mentioned, one less engine to maintain
should cost a bit less since you are not buying another engine, pump, & reservoir
always cool to have one more attachment ;)
Disadvantages:
cycle time will be based on the volume and flow of your tractors hyd pump
will require a rear remote, unless you plumb it from the FEL quick connects
will add more hours to your tractor engine to run it (but that's why we buy tractors!)
as mentioned already, it's not as portable as a standalone log splitter
   / Tractor Log Splitter #6
I read an earlier post about this approach being problematic -- the bungee cord one. Is it okay to do this? I think JJ authored that post. If it works, and doesn't damage anything, I'm in!
   / Tractor Log Splitter #7
I checked with the local dealer's shop foreman, as long as the splitter valve is an "open center" valve, no problems! ~~ Lowell
   / Tractor Log Splitter #8
I have a 3PH splitter. It has it's own PTO pump and is not dependent on tractor hydraulics, so it's MUCH faster. I believe it's also more powerful as it's a bigger pump.
Advantages: No extra engine to maintain. No tires to go flat. I can't prove it, but I'm pretty confident that it's more fuel efficient. With a 20 horse diesel running the pump, it's darn sure more powerful. With the 3PH, I can set it to whatever height is comfortable to work with. Or, lower it right to the ground to set a big round on it. Moving it to wherever is just a matter of hopping on the tractor.
Disadvantages: Initial price was fairly steep but not really bad for the power. It's a bit of a pain to put on and take off. It ties the tractor up when it's in use, but that just takes a little planning.
I usually have the splitter on the back and the forks and grapple on the front. With the tractor and a chainsaw, I have everything I need to turn tree length logs into firewood.
Works for me.
the tractor does have rear remote hydraulics so I can just hook up there, the tractor is 45hp but I don't know the hydraulic flow pressure off the top of my head.
I was looking at the DR 3PH splitter which splits in both directions, so you don't have to retract the head every time, haven't decided on it, just seems like an interesting idea.
EDIT: DR is out, just realized its only 13 ton.
   / Tractor Log Splitter #10
I prefer a stand alone splitter so I can use the tractor/grapple/carry-all when I'm processing logs into firewood...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
