murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,527
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Keep this up and someone will make a movie.:jaded:
The above posts were directed at you...just on this single thread alone. Your obvious directionless aggression vs knowledge is pretty sad.
I will generally use the term "short across the solenoid" (or "short across the solenoid terminals") as that describes what is happening and is generally understood (even by non-mechanically inclined siblings).Correct. The term, "shorting the solenoid" could also be better said by saying,
creating a "loop" or "bridging" the solenoid, but the term "short" is more often used.
Perhaps this is why it does get confusing at times, since in actuality, the solenoid is not "shorted" at all. Until you throw a "ground" loop in there, via a wrench etc.
Aaron Z
Some things never change.
I agree you can make s bad choice at any age. I thought I had kind of grown out of some of those decisions though. Obviously not. I should have disconnected battery or atleast double checked the shifter out of gear. Good news at the Dr. today. Everything doing good, x-Rays show everything back where it should be. It's been 3 weeks since accident and told at 6 weeks normal activity ok within reason. I'm not sure when I'll be back to 100%, but have high hopes it will be soon. Time will tell & I'm getting a little better each day. I'm very greatful for everyone's prayers, well wishes, understanding and support. It has helped much.
I skipped some post because of the be in some posts.
Gary glad your progressing in your recovery.
Ill try and put the stupid argument about shorting to bed.
Imagine you put a 50 amp fuse in line at the battery.
Short across the solenoid terminals, you pick up the load from the starter.
Now short the solenoid to ground. The fuse will blow.
Here we go again, only the names have changed.
