WranglerBowman
Member
- Joined
- Jul 7, 2011
- Messages
- 25
- Location
- Dentsville, MD
- Tractor
- 1946 John Deere A, 1964 MF35, 1958 MF 50, Farmall Super A's x3, Farmall 140, Farmall Cub, Ford 3000, JD 1520
I have a John Deere X585 that I picked up knowing it had issues but figured they wouldn't be too hard to fix (fuel sending unit, power steering, missing parts). I went to drain the oil yesterday only to discover that there wasn't a drop of oil in the engine at all which had a lot of bad thoughts running through my head. I know the engine is not seized as it turns over but never starts. I poured a little bit of oil into the oil filler inlet and noticed that oil was leaking from the bottom of engine. After careful inspection I found that there is a hairline fracture on the very bottom of the engine block. The engine is a Kawasaki 745cc twin cylinder engine. I wanted to find out what people's opinions are on repairing this crack which is about 3 inches long, I'll add some pics later so you can see where it is. I believe the block is made of aluminum and after looking at diagrams of the engine buying a new block and rebuilding the engine is not something I'm willing to do, especially considering the tractor only has 330 hours on it. Please let me know what you recommend as my initial thoughts are finding a good welder who welds aluminum. Thanks.
