Considering a used BX
/ Considering a used BX #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am looking at a used BX2230 with 1500 hrs at a dealer. It has a 60" MMM, no loader. It looks like it has been well taken care of and everything seems to be working properly. Price is $4800. Does that sound like a reasonable price?
/ Considering a used BX #2
Not a bad price. There are a few BX2200/2230's on the market for under $5k with MMM but no FEL, generally 1,000+ hours. Really clean ones with under 1,000 hours go for more, and the ones with FEL's jump quite a bit, sometimes approaching $10k asking price. That's probably a bit steep, but the FEL definitely adds value. You might dangle $4,500 out there and see if he bites. That would be a steal considering you can drop $3,000 and more into a box store lawn mower these days.
Give the mechanicals a good inspection and work out... engine, hydraulics, HST, wheels and axles, frame, etc. Make sure the 3 point will lift an implement and hold it; the HST should be able to spin the wheels in the dirt if pushing/pulling on an immovable object (Note: the BX wants to have the engine revved up for hydraulics and HST to operate properly... that's normal), engine should not smoke or run hot or rough, steering should be effortless. Run the mower and see how it cuts. Make sure rear pto is working. Make sure the plastic HST cooling fan has all blades intact. Check for leaks, evidence of major repair or repainting.
Good luck!
/ Considering a used BX #3
If it's a "clean" maintained BX the price seems "good" to me.
Current thread has an owner facing a $1900 or more bill for repair on his used BX. Buy used and you buy the potential for more problems and most or many of you believe that's the best way to go. I bought used for years because that's what I could afford.:) $4800 to $4500 allows a lot of money for possible future repairs vs cost of new BX. If your borrowing the money to buy the used one you might should check monthly cost for a new one with your Kubota dealer.
/ Considering a used BX #5
Sounds about right to me, give or take, provided the deck is in good shape and it needs nothing (good belt, good tires, etc).
2022 Kubota Z422-54 Zero Turn Mower (A63118)
2022 Kubota...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2015 Ford F-250 4x4 Cab and Chassis Truck (A61568)
2015 Ford F-250...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
