Pulling Trees and Stuff
/ Pulling Trees and Stuff #1
lzicc
Pittsburgh, Pa
Kubota B2650
When you pull a tree down or whatever using a chain, what part of the tractor do you attach to? I have a backhoe on mine, so there is really nowhere to pull from and I don't want to attach the chain to the backhoe bucket. Same with the front, I have a FEL and don't want to hook there chain there to pull. Any suggestions?
/ Pulling Trees and Stuff #2
Is there a drawbar maybe under and forward of the backhoe ?
I don't know if I can have the DB on with the BH on or not. If I could, the chain would put pressure on the bottom of the BH when pulling since the other end of the chain will be high up on the tree.
/ Pulling Trees and Stuff #4
I hook on to the FEL using my welded on chain hooks. The FEL will take all the straight pull force that the tractor is capable of without damage. If you have two hooks like I do, then make a Y so the top of the Y is hooked to both hooks then back to the chain so the top legs of the Y are equal. That way you have equal forces on both sides of the bucket.
If you have tie-down points under the tractor like I do on my B26, you could hook on to them and then swing the backhoe out of the way so the chain doesn't hit the bucket. I don't think it would bother anything under the bottom of the backhoe, but take a look to see that nothing thin or flimsy is in the way when you take the slack out of the chain.
/ Pulling Trees and Stuff #5
I am not sure what type of situation you might be referring to. A tree that has been hung up after you chainsawed it down? A windblown tree knocked over but still on the stump? A small 4-6" diameter tree that is still in the ground you are trying to knock over? Each of these situations can bring either the same or different technique to get the job done. A backhoe makes the job easier in my opinion and I would not hesitate to use either the fel or backhoe to solve such.
/ Pulling Trees and Stuff #6
My BH has a grab hook welded on one stabilizer leg near the inner pivot point. Works good for pulling whatever.
/ Pulling Trees and Stuff #8
I've got two twisted stabilizers from just running into trees at very slow speeds.
Different with a large backhoe.
/ Pulling Trees and Stuff #9
Here is how I remove trees, well pines mostly, usually 6-8" diameter but occasionally up to 10". First, I only do it when the soil is a bit wet, not when bone dry. Approach tree in first gear, low range and make contact with the bucket about mid height, maybe 6' up the trunk, then give it gas until the tree starts to lean a little. Reverse. Lower bucket and hook bucket edge under root ball that is now sticking up a little. As I give it a little gas, still in first gear I rotate the bucket back. This usually works like a fulcrum and pops the tree out of the ground. Done. No tree. No stump.
/ Pulling Trees and Stuff #10
I've only got a BX and no backhoe on it. But I can't understand why you wouldn't use the backhoe and just dig it out. :confused:
/ Pulling Trees and Stuff #11
take the backhoe off the 3pt hitch. so you have access to the 3pt hitch, and more specifically to the swining draw bar. it will be located directly below the PTO shaft on back of tractor.
some dealers may low ball ya, if you get a backhoe at same time you get tractor, and not give you the extra lower lift arms, swinging draw bar, check chains, etc... you may have to spend a little cash for the basic 3pt hitch stuff.
/ Pulling Trees and Stuff #12
Do that quite a bit myself ...
Ya just gotta remember to check for any widow makers before ya start pushin' ... and keep an eye on the top of the tree while you're doing it ... just in case there's something there that wasn't apparent before you started.
/ Pulling Trees and Stuff #14
I had a tall 20" diameter poplar on my wooded property that was leaning towards the road. There was not enough room in the woods to drive the tractor in the direction that I wanted to pull the tree so I used the backhoe to pull it. I extended the hoe and put a chain around the bucket teeth. My original intent was to pull the tree enough so it would fall away from the road when I started cutting, but once I started pulling with the backhoe I realized it could it could pull the tree right over. I had to take the slack out the chain a couple times. From a distance safe from any falling branches I was able to pull the tree over through the branches of the neighboring trees right to the ground. I have used the same technique several times since then.
/ Pulling Trees and Stuff #15
Maybe I don't understand but why can't you just hook a chain to the drawbar mount, or does one not exist? I would think the sub-frame mount would have something you could get a chain around.
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
APPROX (12) REGENCY STAIR KITS (A64281)
APPROX (12)...
