Some attachments I made this year
/ Some attachments I made this year #1
scons
BE
NH Boomer 50
Well the title says it all ...
Hay Bale Pikker
Manure Fork
After first use
Post Hole Digger
Goes about 1m40 deep (+/- 55 inches)
Drilled test hole
Greetings
/ Some attachments I made this year #2
Nice!! Stop by anytime!!
/ Some attachments I made this year #3
:thumbsup:
/ Some attachments I made this year #5
I'm going with an A+ on these things with extra mention for the post hole digger. Make anything else?
/ Some attachments I made this year #7
/ Some attachments I made this year #8
Do the tines have to be hardened on the manure forks or does the extra thickness compensate?
Again, great workmanship and good looking welds.
/ Some attachments I made this year #9
A+++ Great work! How long did it take you to make the bale fork?
/ Some attachments I made this year #10
Those sure are some nice looking welds. I did not open up your pictures the first time I looked at your thread, but now that I did, WOW! Where did you learn to weld like that?
Nice work. I really like that manure fork, could you post more pictures of the trip mechanism.
I'm making some decent plans of it, keep a little patience ;)
Thanks
It probably would be better and stronger, but these were 25mm bars, 30mm might have been better, bought forks even more, but I wanted to keep it low budget since this attachment is only in use 1 time in a year.
They did the job nicely, and I did play them hard ! Only 2 bent a little getting stuck on a piece of wooden beam that got stuck in when I drove full throttle into the pile. But that was my own mistake. Rebend them and they're good to go again.
Umm, it was prepping some hours after work, then welding up. So if you have the material, cutting, drilling and welding would take less then a day if you have some (little) skills and can take some time for it.
Thanks for all the compliments guys. I'm glad I found this forum too !! Tons of info on it :).
In the "pipeline" are a FEL, woodsplitter, snowshovel, ... many more to come. I'll keep you guys updated.
/ Some attachments I made this year #17
Yah Tom , I dont think a guy gets a hand that steady welding only for himself. And probably not in a year either. Is that a high frequency MIG?
Scons if thats just one year I'd sure like to see what you've done in other years.
/ Some attachments I made this year #18
You can get 70cm manure tines for 12.50 a piece. Hardened tines have a yield strength of 1000-1200 n/mm2 where mild steel only has 235n/mm.
That's pretty much the time I got into welding. But it's not me, it's the equiptment that earns the compliments.
Lincoln Powertec 350C Pro
Not much, couldn't weld before.
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
John Deere 8330 (A64126)
John Deere 8330...
John Deere 410D Backhoe (A62679)
John Deere 410D...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
