F 450 Super Duty gasser
   / F 450 Super Duty gasser #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Making a 6 hour drive to look at a 2001 F450 splicer body truck with bucket. It's a V10 gas job with auto trans. Might be a replacement for my 1997 F Super Duty 7.3 PSD flat bed bucket.
It's got 153k on it, but hours shouldn't be an issue as bucket hydraulics work off a couple of deep cycle batteries like my current one does without needing the engine running. I like the splicer body. It's also got A/C in the cab, which I don't currently have. It also has an inverter, which could be a plus if my generator puked while I was on a job. Very seldom do I find power close enough to run my gutter machine so we're self contained that way.
I generally only put 3000-4000 miles per season on a truck. But it pulls a trailer weighing 52-5500 most every day.
Any particular issues to look for on this motor or transmission? Thanks in advance.
   / F 450 Super Duty gasser #2
The v10s had a habit of spitting out sparkplugs.
   / F 450 Super Duty gasser #3
I have a 99 f350 v10 it has 375,000 miles on it and purrs like a kitten.:cool2: The 4100 auto trans is alright if not beat on . mine was totally rebuilt at 225,000 miles but i beat the p out of it .:DIt has 6 inch lift 38 inch tires . Towed over 25,000 lbs hald 3500 lbs. Blew 1 spark plug out :eek: took it to a regular mechanic he said it was no big deal charged me 150 because it was in back of engine he said comcast has a fleet of them and and towing companies and motor homes getting 400,000to 500,000 no problem just change oil and regular maintance. trans was built to haul 30,000 lbs handle 1000 hp 2000 ft lbs tourque.:thumbsup: V10 doesnt have balls like my 460s or 7.3s but it runs like a clock and u dont even know its running.:drink:
Thanks for the information. As far as balls, my 7.3 is no ball of fire. It does OK, mainly because I chipped it, did a 3 inch downpipe and upgraded the intake. If I buy, and at this point it's only an if, I'd probably take a good look at what it has for a transmission cooler. I swapped out the stock one on my current truck and trans temps are dramatically lower. http://www.dieselsite.com/specialordertru-cool4739transmissioncooler.aspx
   / F 450 Super Duty gasser #5
The V-10 was one of Ford's best kept secrets. Think about it, they seldom come up for sale. My dad has a 1999 with a 7.3L. It is no speed demon but it has good torque. I think the V-10 would be cheaper to run.
I think my truck got 10-11 mpg with no load, no trailer on the 6 hour ride home from where I bought it. It's probably more like 8 or 9 hauling my trailer locally every day. Maybe worse, I haven't done any calculations in quite some time.
But then again I'm not looking for a mileage machine. If it were about the same, gas is much cheaper than diesel in these parts. Like 30-35¢ per gallon. The bucket has about the same reach as my current one. I'm more interested in updating a few years and getting that splicer body as well.
Done deal. I just have to make another trip to deliver the rest of the money, insure it and get a temp PA tag to bring it home. It'll probably be almost 2 weeks before it's final, but the deposit is there and the truck is mine. Went down and looked it over and drove it about 10 miles today. They showed me all their facilities and introduced me to most of the crew. Quite a selection of bucket trucks there.
Now to get some pics of the current one and get 'er listed. But here's the new (to me) truck.
   / F 450 Super Duty gasser #8
Neat how the boom is mounted on an enclosed bed. Around me, all you see are booms on service beds. My brother and I went to a DPW auction one time. We bid on a 1970's F350 bucket truck. We didn't win. Just wanted it to limb trees and whatnot.
The motor & electronics are inside the splicer box, keeping that stuff out of the elements. First time I'd ever seen a setup like that.
   / F 450 Super Duty gasser #10
Great buy. My uncle has had three V10 Fords. All great trucks.
Chris
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
7ft Double Legs Lifting 5/16 G80 Chain Sling (A49462)
7ft Double Legs...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
2025 LandHonor HAG-12-12Q Hydraulic Hay Accumulator Grapple Skid Steer Attachment (A49462)
2025 LandHonor...
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
