What color
/ What color #1
tooln
North Central WI
Kioti DK45SE-HST
I'm in the market for a CUT in the 35-45 HP range. I've got quotes on a JD 3038e, New Holland Work Master 40 & a Kioti DK45SE HST. All are near the same price. From the specs the Kioti weighs more, has a higher hyd. flow (gpm) and rated to lift more than the other 2. JD & NH are names I know, are the Kioti's any good? Thanks for your input.
/ What color #2
tooln,
Yes, Kioti is a good tractor. Add to your list LS and Mahidra tractors. All are good tractors, you need to find the tractor brand that best fills your needs and your body.
/ What color #3
I cant believe that you haven't looked at Kubota or LS tractors. LS has been around for many years but only came to the USA about 5 years ago. They build many of the CUT tractors for other brands including New Holland. Check them out, they are usually a bit cheaper and have standard features that other brands consider options and charge extra for like rear remote hydraulics.
/ What color #4
Do a search of dealers in your area and keep an open mind.As stated a lot of the compact tractors the "main" manufactures carry are built by someone else and somewhere else.
/ What color
I have considered Kubota and it was one of my top 3. But it came off because I don't like the treadle.
/ What color #6
The treadle peddle was the biggest disappointment I had with the Kabota. I went with the Kioti DK40 and couldn't be happier with its performance so far!
/ What color #7
I have both a Kioti and a Kubota, and I can switch between the treadle peddle on the Kubota and the twin pedals of the Kioti with no problems. That would not be a factor if I was buying a tractor.
/ What color #8
The WorkMaster series isn't really a direct comparison to the others... It's a more basic model, the ones you mentioned from JD & Kioti have much more features.
You'll need to instead compare the Boomer 47 (or the LS XR4046)... also look at Massey if they are near you.
/ What color #9
A Kioti DK45SE is a very nice machine with a lot more capability and features than the other two you mentioned....and a really powerful loader. Dollar for dollar, Kioti is hard to beat and they've got enough history now that I would be confident they'll be around for the long haul.
/ What color #10
I assure you the rocker pedal was the main reason the Kabota was taken off my list. Just because some folks don't mind it dosnt mean others will or can tolerate it.
Ever single Kabota dealership I went to admitted that many people have not liked the treadle pedal and even admitted that they have lost some sales due to it. Why should I pay the kind of money we pay for one with things I/we simply cant stand when we can go down the road a few miles and get something that has a much better user friendly system for the same or less money? Yes it is a deal breaker for me and if I had to start shopping again tomorrow it would be again!
There are many good machines out there to choose from and if the manufacture wants to install a cheep and uncomfortable system for whatever reason and force it on you with no other options then vote with your wallet and buy the machine that conforms to your wishes/needs and wants not some other persons Idea of what they can or should tolerate .
/ What color #11
tooln,
I thought the Workmaster is an LS in N.H. garb.
/ What color #12
Of the 3 tractor the OP mentioned, the Kioti is the best choice. The JD and the NH are the basic economy models, while the Kioti is the deluxe tractor of that series. If you have a good quote on a DK, get it, because the series is no longer in production and are becoming very hard to find now new. The DK is also thought of very highly around here. If you want the comparable JD, look at the R series, although they are quite a bit more expensive. Also the Kubota Grand L series does not have the treadle, and very nice tractors, although you are looking at about 30K baseline. LS is good too, although they are quite a bit lighter for their horsepower than I think they should be, this can be good or bad depending on use. I could name every maker out there, but you have to set limits somewhere. In my opinion, when I looked a few months ago, the Kioti DK was the best value tractor in terms of horsepower and features for the price. I ended up with a CK for size reasons, but in your case, especially with JD dealers attitude, I would go with the DK and not look back.
Some bias here, but not much. If not Kioti, definitely look at LS, and the Kubota Grand L3560 if it's in your budget.
/ What color #13
There's no reason you should buy one if it bothers you. But just because it bothers some people, doesn't mean it will bother the OP. And vice versa, just because it doesn't bother me doesn't mean it won't bother him.
My point was that someone who is new to tractors shouldn't cross Kubota off their list just because of the treadle peddle design.
This is sorta like the old BMW motorcycle turn signal switch design. There were people who hated it, and others who loved it, and others (like me) that just didn't care. I had multiple bikes with both kinds of switches, and never gave it a second thought.
/ What color #14
Growing up, my father had a Troy Bilt gtx18 that had a "treadle" style setup. I can honestly say that I prefer that over the "separate peddle's" design that is on my JD garden tractor and on my Mahindra 4035. I think i like the treadle design just because I spent a good amount of time using that setup, so thats all I was use too.
Sorry for getting off topic on this thread lol.
I actually pulled the trigger on a Mahindra 4035HST a few weeks ago. I also worked into the deal a 6' LandPride cutter and 7' LandPride rake w/wheels. I liked the 0% for 84 deal as I was looking to keep my payment lol. I shopped around, looking at Kubota, Deere and Massey, but I like what I was getting with the Mahindra 4035 as far as specs go and liked the financing options. I was interested in Kioti and LS, but never really pursued them.
Instead of buying the expensive brand tractors(Deere,Kubota), the money you save by going to say Mahindra, Kioti, LS, might allow you to move up in tractor size or buy attachments.... just some food for thought. I like my Deere ridding tractors and Backhoe(1966 JD300), but couldn't justify spending more money. My advice is, take your time and do your research till you know exactly what you want. Good Luck!!!
/ What color #15
Actually if he looked at it and sat on one and didn't like it even sitting still he should skip it and go to an other brand with a more comfortable set up. It really dosnt matter if he is new to tractors or not. What matters is what he likes and is comfortable with especially since he is new!
/ What color #16
I've had two Kiotis and would buy another without hesitation. Major bang for the buck advantages over JD, NH and Kubota for equally reliable well featured tractors. Downside is smaller dealership network. My 2007 DK40se HST has never needed to go back to a dealer. I change fluids myself and the only warranty issue was a leaking fuel bowl after three years. My dealer and the UPS man got me the replacement part in three days. Very happy ten year Kioti owner here.
/ What color #17
I went from a gear drive (crash box, not a fancy shuttle shift) Kubota to a Grand L with the treadle pedal, and didn't much like it at first... but then, after using the tractor several times, I realized I was getting used to it, no problem! It actually works pretty well for the intended purpose. And, from what I read here on TbN over the years, Kioti is definitly worth giving consideration.
/ What color #18
I went the other way. My first Kioti CK20 had the treadle pedal and the DK has dual pedals. I was used to the treadle but never particularly liked having my foot trapped in the same position on the pedal all the time. The dual pedal system allows you to move your heel around. I could use either system without problem but rather prefer the separate pedals now.
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
INOP/NON-RUNNING 1998 International 4900 Cab/Chassis Truck, VIN # 1HTSDAAL5WH539755 (A61165)
INOP/NON-RUNNING...
PIECE OF 5"X5"X40'-1/4" THICK TUBING (A62131)
PIECE OF...
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
