Attachment Sizes/Ratings
/ Attachment Sizes/Ratings #1
BCMac
Horsefly, BC
John Deere 3255, Massey Ferguson 35, Massey Ferguson 1080, Ford 8N, John Deere D110
I am looking for a few attachments for the tractor. Namely a box blade for driveway work and general leveling and a 3pt rear blade for snow removal.
I notice a lot of them mention for up to 25hp or 25-40hp etc. What is the purpose of these ratings? Would using one on a larger tractor cause issues? Or just not fit size wise? Or would my 80hp tractor just end up bending or breaking the blades?
/ Attachment Sizes/Ratings #2
Blades rated for larger tractors are generally much stronger. I have gotten away with using light duty attachments, by being careful. I have also twisted a light grader blade badly after hooking a ledge. When it happened the tractor didn't bog down at all.
If you intend on working the attachment at all, I would suggest you stay away from the light duty stuff.
Bill
/ Attachment Sizes/Ratings #3
You will also need to pay attention to whether the attachments are sized for Category 1 or Category 2 three point hitches. An implement that's rated for a 25 - 40 hp tractor will be have a Category 1 3 point hitch setup. Your 80hp tractor probably has a Category 2 three point hitch.
And, yes, as Bill said you can tear up equipment that's rated well below your tractor's size.
Thanks guys. I assumed that would be case that the tractor would just bend the lighter duty stuff without skipping a beat.
And yes, my tractor is Cat 2, but I understand there's reducer bushings to take care of that.
/ Attachment Sizes/Ratings #5
Yes, there are reducer bushings. And some implements, like my Gannon box blade, are category 1 but could handle a Cat 2 tractor. But most Cat 1 implements are not built that heavy.
/ Attachment Sizes/Ratings #6
Rear Blades and especially Box Blades are dependent on weight to cut.
Buy Category 2 implements.
/ Attachment Sizes/Ratings #7
For your size tractor, (80 hp) you need to figure at a bare minimum of 800lb+ implements for what you are looking at and really 1000lb+ implements would be much better.:thumbsup:
You may want to consider a land plane grading scraper (LPGS) for maintaining your drive. Much faster and easier than a box blade. ;)
/ Attachment Sizes/Ratings #8
Man MtnView, how many times have you posted those pics? (I'm not complaining).
Can't wait till I get my LPGS. Maybe this spring.........
/ Attachment Sizes/Ratings #9
I know, I need new ones, but, I need time more than anything, that and some rain, no rain here in Southern California for quite some time now. :(
/ Attachment Sizes/Ratings #10
BC- be careful with implement ratings, Often times they are for 2wd ratings. I think EA lists both 4wd and 2wd capacities(Atleast their extreme duty box blade did). I will also agree that some of the older cat 1 stuff was built heavy enough, but anything newer will need to be cat II for sure. The heavier implements also work better since out machines don't have any down pressure.
/ Attachment Sizes/Ratings #11
What I wish manufacturers would do is rate by gross weight of the tractor and HP ratings. Land Pride does this on their RBT series rear blades.:thumbsup:
/ Attachment Sizes/Ratings #12
Noticing the height of the sides, I was going to ask if he ever fills it up ... and then I looked at the 3rd picture ... holy crap ... yeah, I guess so ... :eek:
/ Attachment Sizes/Ratings #13
Remember though, you can't move any dirt with these things. :rolleyes: The sides are 22" tall and 84" long. I figure at a minimum I can move 3 cubic yards at a time, if the ground has any moisture in it at all. I use it for moving large amounts of dirt when I want to even out areas. Waaaaaay faster than the box blade. :thumbsup:
/ Attachment Sizes/Ratings #14
Nice set-up, will that do gravel as well?
/ Attachment Sizes/Ratings #15
Yes these types of implements do gravel. I assume that you are talking about roads. You won't move large amounts at a time like can be done with dirt though, not that they were even intended to do that. Just a side benefit. :cool:
/ Attachment Sizes/Ratings #16
Yes, It was about roads, thank's for the info.
I was thinking along the line of maybe adding a little gravel, then ride the road to fill in pot holes.
/ Attachment Sizes/Ratings #17
I would do the road first and then see if more gravel is even needed. You may be pleasantly surprised. ;)
/ Attachment Sizes/Ratings #18
That would standardize things way to much and make comparing implements way to easy! Where would the fun (pain) of implement shopping be then? (That was sarcasm in case anyone missed it)
/ Attachment Sizes/Ratings #19
Just asking... ?
Isn't the HP is direct proportion to the size/weight of the tractor.
As the HP goes up so does the size of the tractor !
/ Attachment Sizes/Ratings #20
