Kubota 2750B snowblower comaptibility
/ Kubota 2750B snowblower comaptibility #1
Dusteater
Harrison, ME
Kubota BX24
Can anyone help me determine if the 2750B snowblower will mate with my BX24? I have the BX2751 quick hitch and the BX2753 mid PTO kit . Everything looks right, but Kubota docs are not the most user firendly to determine cross platform compatibility. Thanks
/ Kubota 2750B snowblower comaptibility #2
According to the Kubota charts, the 2751 and 2753 fit the BX24. They don't list the 2750B blower, they list the A, C, and D but not the B.
Harvey
/ Kubota 2750B snowblower comaptibility #3
Don't know why it wouldn't!
/ Kubota 2750B snowblower comaptibility #4
Not enough information.
Is your blower a BX2750B, or a B2750B? If a BX2750x, then yes it will. I have a BX2200 with a BX2750B blower. I believe that the letter designation at the end changed as minor modifications were made to the design, but A-D are all basically the same attachment.
The B2750 is a 50" front mount blower designed for the B-series tractors. If you DO have a B2750B, I'd try it - it might is beefier than the BX blower, which is pretty wimpy - I'd be surprised if a B blower didn't connect right up to the BX quick-hitch mount.
Edit: I just ran across some info - the 2750 blower is the same - there may be a different mount for the B subframe, but the blower is the same. I believe that the BX2750 /B2750 blower is the same one used on the Kubota Garden Tractors as well. If you find that the mount is a little different, you can probably make it work - it's pretty basic. You could also get a new mount to mate with the BX2751- they are listed in the parts manual.
Bobcat 60� Tine Rake (A64047)
Bobcat 60� Tine...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2023 Case TV450B Track Skid Steer (A64047)
2023 Case TV450B...
