Kubota 2750B snowblower comaptibility
   / Kubota 2750B snowblower comaptibility #1
Dusteater
Harrison, ME
Kubota BX24
Can anyone help me determine if the 2750B snowblower will mate with my BX24? I have the BX2751 quick hitch and the BX2753 mid PTO kit . Everything looks right, but Kubota docs are not the most user firendly to determine cross platform compatibility. Thanks
   / Kubota 2750B snowblower comaptibility #2
According to the Kubota charts, the 2751 and 2753 fit the BX24. They don't list the 2750B blower, they list the A, C, and D but not the B.
Harvey
   / Kubota 2750B snowblower comaptibility #3
Don't know why it wouldn't!
   / Kubota 2750B snowblower comaptibility #4
Not enough information.
Is your blower a BX2750B, or a B2750B? If a BX2750x, then yes it will. I have a BX2200 with a BX2750B blower. I believe that the letter designation at the end changed as minor modifications were made to the design, but A-D are all basically the same attachment.
The B2750 is a 50" front mount blower designed for the B-series tractors. If you DO have a B2750B, I'd try it - it might is beefier than the BX blower, which is pretty wimpy - I'd be surprised if a B blower didn't connect right up to the BX quick-hitch mount.
Edit: I just ran across some info - the 2750 blower is the same - there may be a different mount for the B subframe, but the blower is the same. I believe that the BX2750 /B2750 blower is the same one used on the Kubota Garden Tractors as well. If you find that the mount is a little different, you can probably make it work - it's pretty basic. You could also get a new mount to mate with the BX2751- they are listed in the parts manual.
Cat TH407C Telehandler (A52748)
Cat TH407C...
12ft Freedom Chip Body (A51573)
12ft Freedom Chip...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
