I Feel Like an Idiot...
/ I Feel Like an Idiot...
/ I Feel Like an Idiot... #42
I just discovered why you're having trouble with your brake pedal. You have the wrong tractor !!!! :)
/ I Feel Like an Idiot... #43
yeah, that's what I thought you had it first I couldn't figure out why that bolt was giving you such trouble.:)
/ I Feel Like an Idiot... #44
That arrangement is very much like the way the brakes in my '06 DK45 are coupled...very easy and straighforward. I'm at a loss as to why they made is so much more involved in the CK35.
/ I Feel Like an Idiot... #45
I still think why Kioti did it that way is because split brakes on a Hydro just doesn't work . Might even be UN-safe ! Oldpilgrim I take it the pic's are of a 2014 Mahindra HST. ? How do you step on the peddle ( forward - reverse ) and still work the split brakes ?
/ I Feel Like an Idiot... #46
/ I Feel Like an Idiot... #47
They work really well on mine
/ I Feel Like an Idiot... #48
I asked the dealer the same ?? when I picked up my Max25. He said that the intention was to set your ground speed using the "cruise control" lever and then use the split pedal.
Seemed cumbersome to me, but, I don't see myself ever using each brake individually so it wasn't an issue.
-J
/ I Feel Like an Idiot... #49
yup 3016 HST and the answer to the other question......it takes a lot of thinking trying to use my heel on the go pedal and my toe on the stop pedal at the same time.
I suspect I'll get a lot of practice this winter.
/ I Feel Like an Idiot... #50
First person to CRASH please post here !
/ I Feel Like an Idiot... #51
That's a rule I try to live by.;)
Using vise-grips on a hex nut and bolt will quickly round off the heads & wreck them. First, use a wrench or socket to wreck the nut and bolt, THEN use the vise grips after you've rounded off the heads. :laughing:
/ I Feel Like an Idiot... #52
Kioti DK-35 and up use the same type split brake lock as the red tractor pics show, EXCEPT the brakes are on the left and the go fwd/rev pedals are on the right, next to each other, where they belong.:)
I agree, and you may remember that was a consideration when I bought the CK. As for the convoluted locking system? Only thing I can figure is because the brakes are on the same side as the HST pedal, they have to be further outboard, with a different angle in the suspended pedals, which prevents the conventional latch from working. but I think it would still work. Well, as we all know, there is no such thing as the perfect tractor.
Karcher G 2800 OC Portable Pressure Washer (A64553)
Karcher G 2800 OC...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
Wooden chair (A64557)
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
