Loader Driveway tear out
/ Driveway tear out #1
midice8
Limerick, pa
Working on it
Anybody ever tear up asphalt with their Kubota BX?
The stuff I'm thinking about taking out is old and pretty crumbly (if that's even a word) already.
/ Driveway tear out #2
I haven't, but sounds doable with a backhoe, not sure if a ripper tooth would work, depends on strength of asphalt I'd guess.
/ Driveway tear out #3
Need pics of tractor and driveway. How much of the underling base are you planing to replace?
/ Driveway tear out #4
Driveway Asphalt is pretty easy to break out as it has very little adhesive strength and is not very thick. You should have no problem with it especially if it is old.
Most of the "Driveway installers" that come by with the old I have some asphalt left over from so and so and can do this drive way for you use inferior grade asphalt with not enough liquid tar in it and usually it is not up to spec for temperature so it is very crumbly to start with.
/ Driveway tear out #5
At our church we replaced asphalt paving with concrete in an area about 14' wide and 40' long. Most of it was against brick, concrete or a steep ivy-covered bank. It's condition had not deteriorated badly, but rather had an uneven surface that made it difficult for some of the older people to walk there.
The one short side was the only good access to rip from. We did make a sawcut roughly down the middle to help loosen things up. This was a Summer project, so the asphalt was softer than it would have been in December. After I managed to get the edge of the bucket under the asphalt it came up pretty easily. It did take a little patience to keep upward pressure on the asphalt while it stretched to the tearing/breaking point.
/ Driveway tear out #6
A buddy of mine tore his out with his 1500 pound CUT and FEL without a tooth bar. It was about 1 inch thick and had "alligatored" very bad.
You should be alright.
/ Driveway tear out #7
I don't think you will have problem tearing it up getting rid of it is another question.
/ Driveway tear out #8
here's where a set of forks would come in handy ... slip under the paving and lift a bit , more forward and repeat ....
/ Driveway tear out #9
It and what is just under it will make excellent fill. If you had enough of it the hot top plants would take it and recycle it but you don't have enough to interest them. If you have the room you can just pile it up and wait for a project to present itself. People get antsy about wasting the asphalt in it today but there is a limit to how many gallons of diesel you should use to save one gallon of asphalt cement.
/ Driveway tear out #10
You can read about (and see the pics of) my adventures in the realm of asphalt driveway removal starting with the 33rd post in the thread below.
New Driveway and Polebarn
I used a Kubota B2910 TLB with a Markham toothbar on the loader bucket. It wasn't necessarily a piece of cake ... all depends on the condition of the asphalt ... and how thick your asphalt is.
Mine was over 6" - and possibly close to 8" - thick in some spots.
I tore out probably at least 400' ... after the topsoil under the driveway was removed, the old asphalt was placed back on the driveway and crushed into place with a dozer to used as the base for my new (gravel) driveway.
/ Driveway tear out #11
It looks like you went about it right. How has it held up for you? It is good to bring up your past experience with excellent pictures to help out the new guy starting out.
/ Driveway tear out #12
The (gravel) driveway has held up extremely well ... it appears to be very stable and I wouldn't have any qualms about paving it (asphalt or 'crete) at this point.
I have added no new material to it since I finished it ... what, 9 years ago ?
A local friend (and TBN member) has commented on how well it has held up ... after inquiring several times whether I had added any gravel.
As the wife has a bad habit of finding every low spot (puddle) when it's wet ... and then driving through them (splashing out the fines) I usually have to hit it with the box blade and smooth it out once or twice per year (spring and fall) ... although I may have missed a year here and there ... :D
The crusher run is pretty thin in some spots ... and I'll occasionally pop a larger stone or two when blading it ... but I try to set the top link and angle the box blade to push things down rather than dig them up.
I need to get a load of crusher to cover the two turn-arounds, which were built after the driveway ... one is just large stone and the other is just crushed asphalt ... and to cover a 30' section of driveway (at the bottom) that I built up about 6" just about a month ago with large stone to alter the flow of runoff, and so I could build up the grade around a grated catch basin in the yard (to prevent the run off from the lawn from draining onto the driveway)
That's what TBN is all about.
Hopefully it will be of some use ...
/ Driveway tear out #13
get a corner of the FEL (front end loader) up under the asphalt, and wiggle the asphalt up some, and let it drop, lift up again, and let it drop, and just go around the asphalt, "prying it up" and letting it drop, eventually it will start cracking completely into manageable chunks that you can just drive the FEL right up and under the chunks to load up and dump some place.
there real no way to cut it without saw and even then the tar would more likely glue it all up. so about only way to crack it up, is to use the FEL like a large pry bar, and raise chunks up and then let them free fall drop in place. it is going to be a messy job in a sense of tearing up yard, as you move the tractor all about going at different angles. but it should be doable,
/ Driveway tear out #14
I find using a loader like that to be a lot of fun. I wore out the bucket of my old 880 David Brown 2WD doing things people said it shouldn't be able to do. :)
/ Driveway tear out #15
:thumbsup:
Looking back on it, it would have been preferable to have a tractor at least twice the size of our B2910 ...
But it got the job done ... just took longer ...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
2022 SUN COUNTRY 53FT NEXT GEN T/A CAR CARRIER TRAILER (A67148)
2022 SUN COUNTRY...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
