I Feel Like an Idiot...
/ I Feel Like an Idiot... #21
I have the same setup on my CK2510. The bolt on the end is a safety and needs to be removed so you can slide the rod to disconnect the two pedals. I did this when my machine was new. Your bolt might be seized/rusted in place. Once the bolt is removed from the end of the rod he rod rotates and slides to disconnect the pedals.
/ I Feel Like an Idiot... #22
What is the purpose of the roll pin #36? what does it have to do with the sheet metal bracket and its slot on the right brake pedal, not shown in the diagram but shown on your photo's. Can you take a photo of the back side of the right pedal and underneath the right pedal.. I cannot make out much depth due to the fact the photo's are blurry. At this time I cannot see how this was designed to work. So if you are an idiot, than I am one too!. :)
I need more photo's
/ I Feel Like an Idiot... #23
Ok, what keeps the rod from falling out.. does the bracket on the right retain it in some way? I can't tell from the photo's
/ I Feel Like an Idiot... #24
I have the same on my ck30,,,the roll pin stops rod from completely falling out . It follows a slot in a bracket to hold in single pedal or double pedal position.. the bolt at the end is supposed to be removed to allow single pedal use
/ I Feel Like an Idiot... #25
My 2013 Ck35 hst has the set up shown in the second pic posted by deerhead. Bolt #35 has a washer between the head and the left brake and is screwed into pin #37. Washer not shown in schematic. I have not tried to use my brakes split yet, but i think buggs is right the washer needs to be removed. The bolt head is small enough to fit through the hole in the brake so put it back together without the washer.
Buggs does your brake pin move from where you set it while driving? The only thing I see holding the roll pin in the notch is the weight of the leg on the brake pin . It should hang down.
I might try to take the washer off of mine tomorrow. Hope I have a big enough pair of vice grips.
Yes, there is a little pin that sticks out from the rod that goes into the slot on the plate. This prevents the rod from sliding out of the brakes completely when the washer is removed. Unfortunately, this pin is missing from my setup for whatever reason. It shouldn't be a problem because I really don't plan to split the brakes much, if at all. I just want to be able to do it.
Sorry about the pics. The light in the barn stinks, and I'm a complete newbie to cameras, I'll see about more pics. I tried from the back, but couldn't get it to focus right.
/ I Feel Like an Idiot... #27
Looks to me like you'd hold the "L" shaped end of the rod with a large water pump plier and put an impact wrench/socket to the bolt?????
/ I Feel Like an Idiot... #28
My 2013 Ck35 hst has the set up shown in the second pic posted by deerhead. Hope I have a big enough pair of vice grips.
Thanks for the educational picture. I never considered putting a dishrag down ahead of time so the blood from the operation doesn't stain the floor mat. You're a thinking man!
Bob
/ I Feel Like an Idiot... #29
Agree. Put a wrench on part 37 and turn. If this fails, get a bigger wrench.
I think you also mentioned you need the roll pin that inserts into the sliding bolt and tracks in the metal bracket that locks it into 1 of 2 positions. These are available at any hardware. Grab a handful of various sizes.
/ I Feel Like an Idiot... #30
It looks to me like you could just cut the end off where it tapers to the threaded nut. It serves no purpose when it has the rolled pin in place.
For me, I always leave mine split like they are supposed to be for using the tractor. Locking is supposed to be for highway use but really unless you have an extremely small foot, just pressing in the middle of both pedals will lock both brakes.
I use my steering brakes to control skid when back dragging or blading forward. Any high side will cause the tractor to ride to that direction so correctly applied force to the opposite side brake keeps you going straight. Steering brakes are also handy to turn the tractor sharper when needed to avoid an obstacle where you might have to stop, reverse and continue to go forward because your wheels didn't turn sharp enough or they are sliding in mud.
If you are going to use a tractor, learn how to use the steering brakes, that is why they have two pedals.
/ I Feel Like an Idiot... #31
I've tried to use them in the muddy area in back. I was using the toe of right foot on the one brake and the heel on the go-pedal. Worked OK in forward but hard in reverse. I could see in a field situation where with the "cruise" on the right foot would be free to brake.
/ I Feel Like an Idiot... #32
it's very difficult to use the foot brakes on an HST tractor. You just don't have enough right feet.
I've tried using the heel on the go pedal and the toes on the brake (sounds counter intuitive, doesn't it) and it takes a lot of thought to try and get your brain to push one harder than the other, but not too hard.
I don't know why the brake pedals or the go pedal isn't on the left on an HST. There's no need to use either one of them at the same time you press the clutch, which is hardly ever used.
/ I Feel Like an Idiot... #33
Many hst tractors do have the brakes on the left, New Kubota 60 series, DK series Kioti's like mine, Many JD machines, some of which have split brakes on the left and a single brake on the right. (best of both worlds?) Some NH etc.
/ I Feel Like an Idiot... #34
For gear tractors, steering brakes can mostly only be used when applying the hand throttle, which I believe is sort of /kind of like applying cruise control on a hyrdo. So essentially you have the same problem of making the tractor go without your feet. Steering brakes are great for steering in mud or when towing and the front end is lite, like when skidding logs or brushing. There are diminished returns to them when you have a 4 wd and are using the FEL. They are also good for Quickly switching the differential to the non spinning tire without stopping and locking it in if your surprised by that mud hole and don't want to lose momentum. Old school solution was like the Johnny popper B I used to drive. It only had 2 pedals consisting of a brake pedal on each side. Only had a hand throttle and a hand clutch. Those were a case of needing another 2 arms if you felt like steering while working the shifter too. Hmm, maybe that's why you could steer with your feet?
The issue here is not that I don't know the use of split brakes, or how to use them. I also have a Farmall H with split brakes, and constantly use them to dodge things like the wellcap or birdfeeder. On the CK, I think it would be almost impossible to brake and steer w/o the cruise on. Why Kioti (and Kubota, etc)couldn't switch the clutch and brakes is beyond me, I can't think of any reason I would want to clutch and move at the same time.
I'll give the bolt another go this weekend and see what happens, if not, not a big deal because it would be of little use to split them anyway.
/ I Feel Like an Idiot... #36
Seems like hydros need a master brake and go pedals on the right ; and steer brakes and clutch on the left.
/ I Feel Like an Idiot... #37
Bob
I'm still sitting here laughing to myself, good one, I guess we've all had these moments which makes it all the more enjoyable.
Steve
/ I Feel Like an Idiot... #38
Solution: spray pin with bolt and washer with suitable lubricant. Remove nut and washer from pin. Place suitable size drift, (punch, nail set) into bolt hole to bottom of threads, hit large end of drift with hammer. Drive pin out, brakes are now split.
Reassemble with grease covering pin, after sanding smooth any high spots on pin. Exercise of splitting brakes just to see if they will complete. Next pointless project on list.:confused3:
Pointless projects? H'mm... I think I have a few more of those. But you do have a point. Because of lawn mower malfunction and tree toppling, I didn't really go at the brakes This weekend. I'll put it on my list to ask the dealer about next time I'm up his way. And I know the brakes will split, I can solve that problem in about 3 sec :), It's just getting them to split as designed. But as this seems to be an isolated issue, I'll move on. By the way, I realized how useful a loader is when I was able to haul the main trunk of a downed tree away in about a minute with minimal damage to self. I like my tractor more every time I use it!
/ I Feel Like an Idiot... #40
A good grapple will make that brush and tree hauling a snap!
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
Case 1044 Combine Head (A65640)
Case 1044 Combine...
Mini Universal Grapple (A65640)
Mini Universal...
