MX5100 Rear Remote Float Valve
/ MX5100 Rear Remote Float Valve #1
TractorBob1529
North Carolina
MX5100DT
I bought the MX5100 the other day and I am want to add some rear remote to the tractor. I would like to have at lease two float valve installed for the TnT setup. Does any one know or have any experience as to how many float valve you can have on the MX5100?
I did some research and search about this subject, but no one seem to have a definitive answer. Kubota notes that you can only install their float valve (L8304) in the second position only. Giving the assumption that the first and the third can only be DA (L8303). Looking at the L8303 and the L8304, the valves are basically identical except for bottom of the valve body.
Looking at the parts diagram, it looks like you would be able to bolt on three float valve in tandem if you want to and have three cylinder that have float function. Has anyone ever had any experience with these valve and their setup?
I know there is a lot of knowledge here, the biggest problem is finding it sometimes!
/ MX5100 Rear Remote Float Valve #2
If you can find a PB line, you can tap into the series flow path and install as many valves as you want.
You can get stacked valves with float from Surplus.
What would be the problem/harm of stacking three float valve (L8304) in a set up that suggest that the stack be DA/Float/DA (L8303/L8304/L8303)? Given the ports and levers are all in identical location.
/ MX5100 Rear Remote Float Valve #4
4 spool stacked valve
POWER BEYOND OUTLET SECTION$39.00 1
SAE8 RELIEF INLET SECTION$55.00 1
4 SECTION TIE ROD KIT$13.95 1
1. DA spool with float
2. DA spool with float
3. DA spool 3 position detent
4. Da spool spring centered
$ 451.85
http://www.tractorbynet.com/forums/...200-rear-hydros-remotes-5525-1-fender-mounted
I am committed now to the Kubota setup. I already have everything to put the remotes on the MX5100, but the valves themselves. I was to add more remotes, I would definitely consider the PB setup. I have the skills/nerve to customize things on the tractor, but I just don't have the time and tools sometimes to do some of the fabrication that you guys take on here on TBN.
It looks like for right now, the second valve with float is a tested method from Kubota. I just wanted to know if any one had the chance to try a three float stack setup on the MX5100.
/ MX5100 Rear Remote Float Valve #6
If they will physically fit, there is nothing wrong with having all 3 with the float function. You can do that on a grand L 60 series. But for whatever reason I believe that the Kubota valves just don't fit and is why only the 2nd valve can have the float function. See if your dealer will take them back if you try all 3 with the float function and it doesn't work. Maybe it will work, only one way to find out.
Good luck.
/ MX5100 Rear Remote Float Valve #7
C4Ranch, do you know what the measurements are for those float valve? The diagrams don't do them justice, there's a whole of room to account for with those float valve cans. But the back of the MX5100 is pretty uncluttered, so there might be some chance.
I know I am not the only person who has pondered on this. Surely somebody who know a Kubota dealer has asked them to try it out or even a dealer who has experimented with it.
/ MX5100 Rear Remote Float Valve #10
I'm not near my tractor but if you look at my link, the pic of the stack is against a 13" tile so that will give you some perspective.
The real deal is the length and bend of the hard lines coming off it. That bolts up to a block on your 3pt cover and tucks your stack up close.
/ MX5100 Rear Remote Float Valve #11
I know on my L, there isn't room for float (or any detent valve with the longer spool) in the first position up against the rear case. And then space limits you to three stacked between the case and fender. The other gotcha I found is that the hoses need to be carefully routed to allow the float lever to pivot all the way into detent. So space is definitely a factor.
The L kit allows float/detent valves in both 2nd and 3rd positions. I can't see why it would be different for the MX unless some other component was in the way.
/ MX5100 Rear Remote Float Valve #12
Your L must be different than my L5240 HSTC. I have float in position 1 & 2.
/ MX5100 Rear Remote Float Valve #14
Ah, I see.. Didn't know when it changed.. I would think the mx would be close to mine but really depends on the 3pt cover casting if it can fit.
From my understanding, the MX5100 is not based on the M series frame, but the L series frame. I would definitely like at lease two float valve and would prefer it in the 1st and 2nd. The third would be for the angle of my scrape blade. I'll take a look at the picture you posted C4Ranch and do some calculations. A guess really.
I guess that is why most the guys here go with after market stuff.
/ MX5100 Rear Remote Float Valve #16
With the current Kubota build program, the Grand L 60s can now have 3 float valves, but the Mxs can only have the 2nd valve with the float function, according to Kubota that is. :rolleyes:
I e-mailed Kubota about the float valve dilemma. They neither confirmed nor denied my "assumption" about having at lease two float valve in the second and third position. Since the first position is physically impossible for a float valve height.
The did replied back that the new MX5200 can have up to two float valve with it's new kit and valve setup. That same setup can be used on the MX5100, but the valves are not interchangeable from old to new, they say. I don't see me spending money to revamp a system I already have.
Does any one know or have any experience with the L8304 float valve, especially experimenting with putting two of them in the second and third position on the remote setup? No crazy dealer who was asked to try this setup out for a customer?
/ MX5100 Rear Remote Float Valve #18
I've heard on here that the MX is based of the old L30.
That is how my L40 was, the 2nd and 3rd could have float. Guess what valve has the float on it, #1.
/ MX5100 Rear Remote Float Valve #19
/ MX5100 Rear Remote Float Valve #20
If you're set on having multiple floaters, I'd just get one OEM float then run an diverter off that and you can have as many floats as you want.
213065 (A64276)
213065 (A64276)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
2018 Case IH Magnum 380 (A64126)
2018 Case IH...
3144 (A63117)
3144 (A63117)
