Cold Zinc Galvanizing
/ Cold Zinc Galvanizing #21
Soundguy, by band couplers, are you talking about using the type that have a compression ring, like Dresser fittings/couplers?
We used to use them out in the field in emergencies when we couldn't repair the threads, or had to torch cut the ends of the pipe.
more like this.
there are many other similar designs, some flat and uncorrugated, some flat and dimpled. etc.
http://www.menards.com/main/plumbin...-culvert/15-culvert-band-coupler/p-114437.htm
the dresser fittings you speak of we use when working on stuff like epoxy coated / steel water pipe.. etc. like 6" 8" etc.
/ Cold Zinc Galvanizing #22
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
