Backhoe L48 sub frame broke
/ L48 sub frame broke #1
messtrap
E. Freetown, NY, USA
Kubota L48
The right side of my L48 sub frame obviously had a lot of water in it and froze over the winter. It has expanded the length of the frame and split wide open. There is no cracks or bad welds where the water could have gotten in. Has anyone with a kubota backhoe sub frame experienced this?
/ L48 sub frame broke #2
That is strange, there has to be an opening somewhere for the water to get in,
maybe a missing bolt etc.
/ L48 sub frame broke #3
My sub-frame is fine and it is exposed to snow,ice,water all winter while clearing my drive. Sorry to hear about your problem, Think I would get the dealer involved.
/ L48 sub frame broke #4
Is the ROPS/FOPS in place and unmodified? With it removed the rear sockets could collect rain. Seems like it would take a lot to fill up the tubing - like being parked where a roof drains on it. My L48's "hat" is off temporarily and your post is telling me to drill some drain holes !!
No openings, it's a boxed frame made of rectangular tubular steel. Kubota rep thought it was from condensation.
The ROPS has never been off the machine. Even if it was, it has nothing to do with the water in the subframe. The part that blew out is the long piece that goes from the FEL brace to the backhoe brace. It is a sealed piece, welded at both ends. Kubota rep advised me to drill drain holes in bottom of both sides of frame for drainage. Putting new frame on, kubota would only cover 850.00 of the 2,444.00. If I knew how to weld I would have fixed the old one.
/ L48 sub frame broke #7
Your Kubota dealer if full of BS. No way for condensation to form in a sealed area. There has to be a hole in the frame somewhere,possibly two with one or more on top of the frame and a drain hole that is stopped up which caused the frame to fill with water. In order for ice to split the box frame, it had to be completely full of water. You need to look more closely to find the hole(s).
I think I would look for a welder to weld up the split if no other damage is evident.
Is the $850 the cost of the frame and the rest labor to install?
/ L48 sub frame broke #8
....... It has expanded the length of the frame and split wide open......
Possibly not freeze damage? - if the crack is long it might be from defective material when it was formed. If the edges of the crack are full thickness and square, the material may be brittle and no good. Composition and forming have to be just right for tubing to have good strength & ductility. There shouldn't be a time limit if its a raw material error - factory should stand behind it.
There are no holes Gary. An engineer friend of mine looked at it and confirmed it was "hydro-formed". The rectangular tubular steel is now round and makes it difficult to put on the backhoe.
The new frame has no holes in it either. That is why Kubota is telling me to drill drainholes in the bottom so it doesn't happen again. The 850.00 is what Kubota gave me towards a new frame at 2,444.00. I have to install it.
/ L48 sub frame broke #10
There was obviously enuf "hole" to allow air to pass back and forth.... Altho one would expect internal condensation to self limit as the air moved in and out in response to temperature changes. However, maybe there was a little oil residual on the metal from forming. The resulting oil film floating on the water would favor trapping it inside.
/ L48 sub frame broke #11
messtrap, is the crack along the top of the tube? Any chance of posting a picture?
Drawing of the subframe attached.
/ L48 sub frame broke #12
Certainly would like to see a picture of the damage.
How old is the machine? Did you buy it new?
/ L48 sub frame broke #13
Condensation? No way. Take it to a weld shop and have it welded professionally - it shouldn't cost more than a hundred bucks, 150 tops.
Yup, crack is at the edge on top of the tube. I will take a pic tomorrow and hopefully I can figure out how to post it. I bought the tractor new in 2009. I'm sure the picture is worth a thousand words.
Did take it to a professional weld shop. Not as simple as welding the crack, the entire leg is hydro-formed and pulled the frame slightly making it hard to get the backhoe on and off. Take a look at the pic tomorrow night when I post it.
I have no idea what I'm doing, these pics are when the frame was still on the tractor. It should be rectangular steel, not circular!
/ L48 sub frame broke #17
That is strange, just curious, has the tractor ever been driven in water.
/ L48 sub frame broke #18
View attachment 391294View attachment 391295View attachment 391296
........these pics are when the frame was still on the tractor. It should be rectangular steel, not circular!
Good pictures. Along the cracked corner, the material looks like it was weak, maybe from the start. The tube also looks curved - like maybe a jack was used there to lift the tractor. If the tube was already weak that might explain the bellying.
Back in my teaching days (metallurgy for engineers) we looked at cases in lamellar failure in rolled material, where the internal layers have impurities with different hardness, severely weakening it.
I'm having a hard time imagining how enough water got in and froze to cause this. But the edges of the crack look like old rust. If the tubing was weak, and a crack got started, it might eventually let in enough rain unnoticed. I dunno.
Is the back end bent where the backhoe attaches? How does the frame tube on the other side look?
Hello rbargeron, the tractor has never been driven in water deep enough to even touch the frame. To answer your questions rbargeron, I'll take some pics of the frame tomorrow, it's sitting in the yard and you'll be able to see all the answers to your questions. The frame was fine late fall when I pressure washed it and got it ready for winter. The spring is when I noticed the damage. (No way the pressure washer filled it either, I can't find a crack anywhere. The existing crack I believe rusted after it burst open. Take a look at the pics tomorrow night, Really stands out off the tractor.
/ L48 sub frame broke #20
messtrap,
From what I can tell on the pics, is looks to me like metal was defective from the factory. I have seen this before when I worked in the sheet metal shop. It is called 'lamination'. That is where slag or dirt got onto or into the metal when it was being rolled in the mill. MOST of the time it can be seen on the flat steel as a shadow or blister. HOWEVER, there are time when it can not be seen until the metal is formed. During the process of bending the steel, is USUALLY shows up as a split or crack. :2cents:
BTW, I have over 20 years experience in precision sheet metal working with mild steel, stainless steel, aluminum, and titanium. Also, 10 years in machine shop and 5 years welding.
Please post pics of unit off tractor. Thanks.
Dave
UNUSED WOLVERINE SB78-78" ROCK BKT (A62131)
UNUSED WOLVERINE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
2008 VOLVO VNL64T T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2008 VOLVO VNL64T...
2025 IRANCH IREAS Semi-Automatic Quick Coupler Excavator Attachment (A60353)
2025 IRANCH IREAS...
