skyhook
- Joined
- Mar 12, 2013
- Messages
- 1,917
- Location
- Canada Ontario
- Tractor
- 1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
You'll need more than just that "one' wire to make it charge.
Not if it is a Delco model 10-SI : https://www.google.com/webhp?source...4&ion=1&espv=2&ie=UTF-8#q=one wire alternator
But her's is a newer model so I don't know if it will work with one wire.
I would try it. :thumbsup:
so now we need a picture of the connector ( and pins ) to figure out which "extra wire" is going to be needed on the half converted alt , to make it fully functional ....
some need a bulb / resistor ( or both for backup ) and some just need an extra wire....
but we still need that big wire going back to the battery in any case...
It looks like something has been added to the pins and the connector filled with potting compound.
It might be easier to run an 8 gauge wire from the alternator to this end of the new battery wire.
So did the battery stay charged before the wire came off?Ive had this tractor for about 20 years and there were never wires run to the pins.
