Is this lever for draft control?
/ Is this lever for draft control? #1
Radius118
Member
Sedro Woolley, WA
JD 1070
I was noticing my new to me 1070 has 2 rockshaft levers. I suspect one of them is for draft control. Is it? If so, how do you use it? It is useful for keeping a box scraper level over undulating ground?
Thanks,
Michael
/ Is this lever for draft control? #2
It is for draft control.
Your manual should describe how to use it.
It may help with the box blade, but usually for more ground-engaging attachments like a moldboard plow, or digger.
If they start going too deep, then the draft control senses this load and causes the 3pt arms to raise until the load decreases. A form of position control.
Don't think it will solve the leveling problem.
/ Is this lever for draft control? #3
Draft control. The farther down you have the lever the harder a ground engaging implement will pull before the 3pt arms raise. It most likely wont keep the box drag level accross undulating ground. It is meant to automatically lift the 3pt arms to even out strain on the tractor. In my opinion it is easier to put the draft control on max and control the 3pt itself than get the draft control adjusted right.
Thanks for the replies and sorry for the newb question.
I did not get a manual for my machine, but I found one on ebay and ordered it. Awaiting it's arrival. I will be sure to read through it once I get it.
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
(3) HERCULES H-903 (A62131)
(3) HERCULES H-903...
PAIR OF 10' RAMPS W/10' EXTENSIONS (A62131)
PAIR OF 10' RAMPS...
2009 Ford E-350 Cargo Van (A61568)
2009 Ford E-350...
22ft T/A Enclosed Trailer (A61569)
22ft T/A Enclosed...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
