franklin2
Gold Member
Duplicate post.
Alright, so I was a kinda taking a middle road here... I could understand people using pvc and figured they were probably alright, but I would use metal of some kind, mostly because I have acces to any tooling I would need for iron or copper. I have since changed my mind.
We have 2" diaphram pumps at work that pump waste water to a holding area in another area of the plant. For those that don't know, a diaphram pump used air pressue on diaphrams to pump liquids... the outlet port of the pump will deliver the liquid at the same pressure as the incoming air supply- we run around 95 psi in our plant. The liquid end of these are piped with 2" pvc pipe (some is sch.40 but most is sch.80). So I went to turn on one of these pumps a couple days ago and heard a large loud "crack" and water started coming from the ceiling. The outlet pipe ran up the wall and up to another pipe along the ceiling, and it broke right at the elbow. Now realize that this was at the top of the run where the pressure would be the lowest and there is no restriction between there and were it dumps into an open tank. I imagine there would be a small surge because the pump had just turned on, but I can't imagine pressure at that point exceeding maybe 50psi. I thought of this thread immediately.I now KNOW what I will run when I do my garage/shop.
Well yesterday the AC contractor stepped on a copper pipe in my attic that connected to PVC pipe and then the screwed into a galvanized 90 in my well water tank. I did not put the tank there. It came with the house. Anyway it dumped the 70 gallon tank contents into the attic, then the pump turned on an added more water. Which piece of pipe do you think broke? The PVC.
If you have missed the posts about PEX you are missing a lot. It is easier than copper, iron, and PVC, safer, wont freeze and burst, can be cut with a Stanley knife, and sharkbite couplings just push on and can be reused.
It also costs much less than copper or steel, but that is a minor advantage. The only disadvantage is low resistance to UV, so don't use it outside. Faster safer easier cheaper .
Find one person who used PEX for air lines and is unhappy with it.
Yes, but it sounds like you are missing the point.
Has anybody looked at these set ups?
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=391196"/>
. . . when you tap off the main for a branch line mount the "T" upward . . .
