JD 3520 adding grapple and rear remotes
   / JD 3520 adding grapple and rear remotes #1
JD Jon
fuquay Varina nc
john deere 3520
I am looking for some help on adding some hydraulic ports to a John Deere 3520. I have been reading a lot on tactorbynet and other forums trying to learn as much as I can. I am looking at trying to add 3 spools in the back and also add lines/joystick controls for a grapple. I believe the 3520 is setup to add a 3rd scv pretty easily and then I figured I could add the power beyond kit for the rear remotes. I honestly need as much guidance as possible (aka tell me like a 1st grader). Below are some link for some of the things I believe I will need. Thanks for any help in advance.
Prince Hydraulics: RD-5300 Directional Control Valve: PRC Industrial Supply
http://www.surpluscenter.com/Hydrau...STATION-DO3-SUBPLATE-OPEN-CENTER-9-5883-1.axd
http://www.surpluscenter.com/Hydrau...12-VDC-10-GPM-OC-DA-SOLENOID-VALVE-9-6136.axd
https://fbcdn-sphotos-e-a.akamaihd....3_10202546654167109_9042895661622189219_n.jpg
   / JD 3520 adding grapple and rear remotes #2
If you want to do T-N-T, I would suggest two of the three spools with float.
   / JD 3520 adding grapple and rear remotes #4
Top link and tilt for your 3pt.
Perhaps on a box blade or scraper for crowning or whatever.
Very useful.
Would the float option work for mmm as well?
   / JD 3520 adding grapple and rear remotes #6
Only if it has gage wheels that you can set for minimums.
Float will drop the MMM to the set height.
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2020 Bobcat T550 Compact Track Loader Skid Steer (A55851)
2020 Bobcat T550...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
2015 Volvo VNL 64T (A57024)
2015 Volvo VNL 64T...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
