Deck Size
/ Deck Size #1
rockerjbgood
Amboy, MN
LX279
Movin to the country. I went from 1/2 acre to 3+ acres to mow. Property has a John Deere LX279 with a 48 inc deck included. Can you equip this mower with a 60 inch deck?
/ Deck Size #2
/ Deck Size #3
Typical deck envy case. :laughing:
Your gonna need a bigger mower to handle going up a foot in size. Like has been said, trade up.
/ Deck Size #4
Yeah, 17 hp won't pull a 60" deck very well unless your grass is very thin and not very tall. Time to upgrade the whole ride.
/ Deck Size
I was just wondering. They didn't leave the manual and I am having trouble trying to find on line the specs for this machine. I'll probably find a book on it somewhere.
/ Deck Size #6
Tractordata.com has some basic info on the JD you have. As others have said, it is time to go bigger. I still have a Ford 1210 that I bought used back around '92 and it runs strong. It is a diesel with about the same HP as your Deere, and is a scrappy little bugger. It handles a 60" Caroni rear mower quite well. It would definitely NOT handle a 60" Landpride I had with an earlier Kubota. That was because the Landpride deck was so much heavier.
I've had 3 different 60" decks when there was about 2.25 acres of grass. It took about 1.25 hours to mow it all. When I got the last Kubota I went with a 72" deck. With the extra width and HP I can do 3.5 acres in the same amount of time it took to do 2.25 acres with the 60" decks.
/ Deck Size #7
"..Movin to the country. I went from 1/2 acre to 3+ acres to mow. Property has a John Deere LX279 with a 48 inc deck included. Can you equip this mower with a 60 inch deck?..."
If it were me, and if all I needed this machine to do was mow grass (the LX279 is pretty-much just a lawn mower) , I would seriously consider getting a zero-turn.
However, you might be ahead to get something more versatile, like a garden tractor or something bigger, that can handle attachements other than just the mower deck.
7102 (A61567)
7102 (A61567)
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
213093 (A64276)
213093 (A64276)
(2) UNUSED 17.5L-24 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
