John Deere Model B/ Farmall H/M/C Question
/ John Deere Model B/ Farmall H/M/C Question #1
vwbusman66
Kingsville, MD
1952 Ford 8N
Hi all, I am considering buying a second/ replacement tractor. I currently have a 1952 Ford 8n that has been nothing but trouble. I am considering either a John Deere Model B or a Farmall H/M/C. I need to be able to at least drag/ lift a blade and maybe even a finish mower. I am curious how one attaches implements to the back of either tractor. Also, how does the lift work? I just need some advice. Thanks, James
/ John Deere Model B/ Farmall H/M/C Question #2
None of the tractors you mention came with a factory installed 3PT hitch.
None of the Farmalls you list had any kind of rear hydraulic lift/hitch.
A John Deere B probably will have a hydraulic rockshaft with no linkage and no position control.
/ John Deere Model B/ Farmall H/M/C Question #3
Something like a Super C Farmall with Fast Hitch, would be a possible candidate for what you're looking for. You can get tongs that fit in the FH sockets, and a top link kit that goes where the belt pulley attachment bolts on. Or, there are a few of the full 3 pt. adapters around, but expensive. Not the true geometry of the 3 pt. system, but they work.
For the money they seem to be bringing now a days, I'm thinking you could find a newer than an 8N, but still 3 pt. system tractor. Lots of choices there, from Ford 600-800 series tractors, Oliver 55 & 550's, IH utility tractors, etc. By the time you find an C,H,M, buy a full 3 pt. conversion, and plumb it up, you could have a pretty nice older OEM 3 pt. tractor, with power assist, or full power steering, and live hydraulics. Something with at least a single set of remotes, which can be added if not equipped with, for a hydraulic top link, etc.
Just my 2 cents...
Hi, so could I get a rear mounted blade to plow snow for a John Deere A/B or Farmall H/M/C. I have found a handful of Farmall C's with hydraulically actuated front mounted snow plows. Any help is appreciated. Thanks, James
/ John Deere Model B/ Farmall H/M/C Question #5
As mentioned, if the Deere has a rock shaft you can get an aftermarket 3pt. hitch for it, as well as the Farmall's. The C will be the only Farmall with live hydraulics, unless someone has added an aftermarket live hyd. pump. Those conversions are pricey. Probably in the $500.00 range.
/ John Deere Model B/ Farmall H/M/C Question #6
I like the old Farmalls, but I'd only consider an H or M if I had some task that they were designed for, like plowing or pulling a disc.
If you want one machine to do different tasks, get something with a 3pt. An international 504, Ford 600 or 800 or 3-4000 series or something like that.
Another idea if you're stuck on Farmalls, would be a belly mount mower on an A and a belly grader on a C or an H. A Farmall for every job.
What is the story with the Cubs? I could use it with a mower (sickle bar or belly) and a plow? did they have built in hydraulics? Thanks, James
/ John Deere Model B/ Farmall H/M/C Question #8
Cubs have live hydraulics and a non-standard PTO that turns at ERPM in the direction of crankshaft rotation, counter to a standard PTO.
/ John Deere Model B/ Farmall H/M/C Question #9
And if everything is up to snuff, has a whopping 9 hp. On a good day....
/ John Deere Model B/ Farmall H/M/C Question #10
My 1948 JD B has a rockshaft that can be used to operate a true 3-pt hitch. YOu can find these on eBay for $500-700 or build your own hitch. Just be sure that the B you're eyeballing has a rockshaft. Some of the older B's (late 1930s, early 1940s) did not come with rockshafts.
My 1951 Farmall Super A normally came with the Farmall two-point hitch. My Super A has been retrofitted with a true 3-point hitch by Caltrans, the former owner.
Good luck
2014 FORD F150 4X4 PICKUP TRUCK (A59906)
2014 FORD F150 4X4...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
