Locating and using a Compact Bender
/ Locating and using a Compact Bender #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
I just purchased a HF compact bender and need to locate it in my small shop/garage. I want it out of the way enough that I can keep it installed most of the time hopefully. Plan on using 4qty 1/2in dia. concrete anchors and bolt it down. Sorry for the newbie question here, but I have never used one before so I am wondering how much floor space do I need all the way around it. Can I put it sort of close to one wall or a corner? I will be playing mostly with flat bar stock no more than 10ft long.
/ Locating and using a Compact Bender #2
there are concrete anchors that are actually inserts.. like nuts that you can bolt into, you could put it in the center of your garage bolt it down and just remove it when your not using it, that way theres not threads sticking out of the floor to trip on... just a thought
/ Locating and using a Compact Bender #3
I bought a hf rod and pipe bender also, I put it about 3 feet from the wall, no problems just position the handle in a fashion that gives you the most articulation when removing the rod or pipe
That's interesting... what I don't want is a trip hazard and thus one of the reasons for mounting it sort of out of the way. I already bought the anchors but I like your idea. Are those a Home Depot item?
When you say articulation, are you talking about the motion of the handle or the metal I am bending?
/ Locating and using a Compact Bender #6
Yes, I think it is a Redhead product. They are 1/2 inch inserts that drive into a drilled hole in the concrete and then set with a drive tool. My gun safe, my drill press and my deck for my fifth wheel are all secured with them. I have yet to have one pull out and the install is really easy. I think the overall diameter is 3/4, but I can't remember for sure as the last one I drove was 4 months ago.
Thanks gator! But dang it... another trip to HD and I can't install tonight. I hate waiting. I am like a little boy at xmas when it comes to tools and messing with them! :D
/ Locating and using a Compact Bender #8
Actualy I was talking about the metal, sometimes it take a little manipulating to remove.. Of course you could remove the roller but I never do!
/ Locating and using a Compact Bender #10
I will say this, I've put very tight bends on 1/2 in steel rod, at the very end of the rod, I weigh 220 and am 5 10, pretty stout for my age still and I put a lot of effort sometimes getting a bend. They better be strong inserts able to handle a lot .
/ Locating and using a Compact Bender #11
I mounted mine on an "outside" corner of my office in my shop. It is secured to the floor with 5/8" concrete anchors. The stomp shear can be moved out of the way with a pallet jack when I am bending longer pieces. image-819619165.jpg Terry
Jesse... good thought. I was wondering the same... regardless whether they are studs or inserts. The inserts theoretically should be better as the bearing stress on the concrete will be less. The inserts require a 5/8in drill bit vs. 1/2in dia. for the anchor bolts. But I suppose I could weld the stand to a bigger steel plate and drill four holes in the larger footprint? The more I think about it the more I like that idea.
/ Locating and using a Compact Bender #13
Or you could get fancy and jackhammer out a section and set a trailer hitch type receiver into the floor. Sorry if someone has already mentioned this. ;)
Terry
I mounted mine on an "outside" corner of my office in my shop. It is secured to the floor with 5/8" concrete anchors. The stomp shear can be moved out of the way with a pallet jack when I am bending longer pieces. View attachment 388127 Terry
Thank you BB for posting that pic! That is exactly the situation I was thinking with it being on an outside corner and I have a cabinet on rollers that I could move if necessary.:drink:
/ Locating and using a Compact Bender #15
I'd weld the plate and do that !!! You'd be surprised how much leverage you exert when bending !!! Mine is in the floor of a gravel barn, I dug a hole with my backhoe and put in hardened bolts thread up ! Maybe overkill but that baby in all that concrete ain't moving!
/ Locating and using a Compact Bender #16
if your really that worried about stress put in a bigger floor plate with more bolts but im guessing your really overthinking this the inserts go into the concrete and to move them you will have to twist/break the concrete I don't care how fat you are that's gonna be hard to do ;-)
You may be right... and since I didn't have a convenient piece of 3/16in plate that is bigger than the stand itself, I went ahead and hammer drilled and banged in the RedHead 1/2in inserts. These worked great. You do need the corresponding set punch to properly seat them and I am happy with the result. Thanks everyone!
Well, I thought it only just... to post a pic of my first scroll. Was pretty easy actually. The little idea/pattern book that comes with... is handy for set up for different scrolls and sizes. I used the optional scroll attachment. Time to make some planter pot stands for the better half!
/ Locating and using a Compact Bender #19
I bent a lot of 1" EMT and discovered I sometimes needed to reposition the work and block my base up due to the length and location of the bends. A rigid base would not have been useful then. I finally just made a good heavy wood workbench with enough of a lip that I could C-clamp my Harbor Freight bender to it on the corners and get to bending. Don't fence yourself in. When thru I just removed the C-clamps and set the bender and its assorted pieces on a shelf in table and had a clear 36" square tall work table to use for other projects in the meantime. I'd take a pic but I don't have any of it anymore.
/ Locating and using a Compact Bender #20
Nice bends, CLAY.
I, too, bought the HF bender many years ago and agonized about where to mount it in my small (625sf)
workshop. Space is at a premium, and I bent some long pieces of 1/2" rod, and want to use it more
for the EMT conduit I use to make ATV racks. The conduit is in 10-ft lengths.
I was leaning towards mid-floor and easily removable because of the lengths involved. I dropped
the idea since I did not think that threaded anchors would be strong enough. (I have already had
some pull out in another application.)
So, I mounted it on my tractor forks. The same receiver is used for my HF tire changer.
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
