New Tractor or Used
/ New Tractor or Used #1
louis2244
Jacksonville, FL
None
I have 100+ acres of recreational land in North Florida that is a combination of hard woods and open and cultivatable land that I want to manage for deer, turkey, duck and dove hunting. I need to mow/bush hog the hardwoods to keep the land open for the turkeys, plant food plots for the deer and turkey, and disk and cut in brown top millet for the doves. I have a small floodable area (3-4 acres) that I would like to plant annually with corn or other crop that I would flood in the fall to attract waterfowl. I will need to do some light road maintenance with a box blade. What size tractor would be ideal for these requirements and should I look for a new or used tractor. Since the property is about 1.5 hours from my home I want something reliable that I can count on with minimal maintenance. Looking for recommendations.
/ New Tractor or Used #2
A 30-40hp ,4WD and FEL.It's up to you to decide if you want to spend xxxx dollars for a new compact or a used utility tractor.Do you plan on trailering?Most familiar with Kubota,owned a L3130 and currently a L4240 and L3000 DT(purchased used) ,all 4WD and FEL and capable for any work you described.
The new 2014 tractors above 25 HP have DEF which you may or may-not want or desire.
Check www.tractorhouse.com for available in your area or maybe Craigslist(be careful there)
/ New Tractor or Used #3
if in trails or woods. how wide are you wanting to go.. that will determine tractor size.
if you aren't into antiques.. but classic ok.. then something in the 4610 / 5610 range.. depending on yuor size needs.
heck.. a 3010s NH would even be nice..
/ New Tractor or Used #4
I'll go counter to that and say a full sized 2wd, used tractor. Maybe a ford-4000 or MF65/165, for discing, bush hogging, ect. I would assume you want to use 6 ft bush hog and 6-7 ft disc.
Edit: I mean counter to the 30-40 hp newer model
/ New Tractor or Used #5
Agree with nybirdman's assessment regarding size and features, although without having seen your place, a larger model might serve well also. One of the old tractor adages says to get one size larger than you think you'll need because there's always more work than first anticipated. Dunno if that's always true, but it worked out that way for me. Also agree with your comment about reliability. It sounds like there's some serious work in store, meaning you want something dead solid dependable so chores get done on time. That suggests new or a used one that's in top condition... you don't want to be forever tinkering with something that has seen better days. That would also favor something that has good local dealer/parts support in case something breaks. Any number of good brands to consider, so shop around and see what's available and what the dealers are like.
/ New Tractor or Used #6
I think the answer to "new or used?" -- regardless of product category -- is always "it depends". It depends on your budget, and what you might want in terms of features and/or brand, and what you think represents value.
In our recent decision of that type, we looked at a couple of used options, one of which was kept in like-new condition. However, their asking prices (from which they weren't going to budge much, if at all), were not appreciably lower than a new tractor (in our case, Kubota was our preference). And after learning about Barlow Equipment (based in Kentucky) on this website, we realized that we could get a better and brand-new tractor for an amount of money above the used alternatives that was a really good deal. We took to heart the advice that nobody really wishes they would have bought less tractor. :)
Great information. I appreciate the input. I like the pointer picture on your post. I used to have bird dogs. Pointers worked best in Florida but I really liked the look of English Setters. Unfortunately wild quail population is so far down you can't justify owning bird dogs anymore. Thanks again.
/ New Tractor or Used #8
New Tractor or Used
IMO...there are two key factors...your budget and your mechanical ability/incentive...
Would you be servicing the tractor yourself? or relying on a dealer etc...?
If you are a capable mechanic etc...you can save a lot of $ comparing new to used...
Tractors are generally quite reliable...once minor issues get resolved...
Good Luck...
Thanks to all the rapid responses. I see lots of Kubota owners responding. It is tempting to go for a Ford or John Deere but I want to look at all the options, especially for new tractors. It is very important that I have a reliable tractor because my leisure time is limited (I have keep working to pay for the toys!). I'm leaning toward pricing new tractors then seeing how willing dealers are to negotiate off MSRP. I assume getting used implements is a good strategy to help offset the cost of buying a new tractor.
/ New Tractor or Used #10
For used, there is a JD-301 industrial loader tractor with box blade and bush hog for $6000 on Jacksonville craiglist. Get a disk and good to go for 1/5th the price of the cheapest comparable new machine. Assuming you can do some work your self.
/ New Tractor or Used #11
How many acres is the wooded area you want to brush hog to keep open? How many acres is the open area you want to plant for food plots? How much time do you want to spend? 100+ acres of open tillable field can take a long time on a small machine, but a big 150 hp cab tractor won't work in the woods so well. We need more details.
/ New Tractor or Used #12
If you are just bush hogging under hardwoods to keep the scrub brush at bay then a 40-45 HP tractor would be ideal. It would be big enough to take on some tough brush and still small enough to get under the limbs. You may have to put on a brush guard similar to what dozers have for clearing, slide bars from front to rear to raise limbs up and over the operator platform. There are some pretty nice ones built by TBN members, just do a search.
This size tractor would handle an 8 foot disk also for your small food plots. 4 WD will allow a 45 HP tractor to perform like a 60 HP or larger 2 WD. I would also look for something with an FEL. When I bought my first tractor with FEL, I was a bit skeptical of the need, but it is an invaluable tool for a tractor.
I also use my back hoe a lot and wouldn't want to be without it. Some folks claim that they are too expensive and should be rented when needed. I use mine just about every time I get on my tractor. I have used it to remove dead trees & stumps, thin out trees in a thicket, dig up rocks (you likely don't have that problem in Florida), dig trenches for irrigation/water lines and drainage, clean out silted in ponds and plant trees. No more shoveling for me. This fall's chore is using it to dig out a bunch of rocks from a new garden spot, they just keep appearing so now I am digging down about 12-18" and getting as many as I find out. I am sure I will have to contend with some missed small ones but getting out the softball to basket ball sized ones that harass my tiller is the priority.
Used can be just a good as new if you find a bargain. Rarely do you find someone selling a slightly used machine in good shape that is not as much as a new one. IF financing the purchase, I would surely go with new rather than new. Many can be had for 0% interest financing AND you can add your equipment needed in on the same payment @0% interest also.
/ New Tractor or Used #13
So fairly level land, some planting and road work. No hills or snow.
I'd agree 2WD and 40-50HP should fit your needs.
Good Luck...
Other key factors: distance from dealer if it has to go there, frequency of use (weekend warrior?), to have a cab or not? How soon do you need it? WIll there be a trailer it fit's if needed to get it to the dealer?
Bargains are out there. I've posted frequently of bargains I've seen and gotten at Public Surplus auctions.
Example:
1991 Kubota L3450 Tractor $4,400
John Deere Tractor Loader 4WDmdl 5300 $9,700
Ford Tractor 3910, $5,200
2002 Massey Ferguson Model 271XE 4x4 Tractor, red and white, 994 hours, with AC unit on top. <12k
2000 Kubota L35 tractor with Front bucket and backhoe attached$10,702 (I should have bought that one!!)
1994 John Deere Tractor with Post Driver $8,900 (or maybe that one)
Or mine -
$11,500. 50HP and 2 rear remotes.
There are other auction sites, CL, local ads and Barlows. If your young, have the money, and are going to be able to work it several hundred hours a year new will be worth it IMHO. But I only hope to be able to use mine for another 20 years. :(
Used will likely require some maintenance, I've had to replace 4 hoses or so and front tires on my M4700 and front tires on my B7610.
If your like many of us you will soon want things like a post hole digger (PHD), tiller, discs, etc. For every grand you don't spend on on the tractor you have a grand for equipment.
Try and determine what dealers are near where the tractor will be located and on your 1.5 hr route from home to land.
Good luck and keep us posted
I'm very appreciative of all the advice. 50 HP and 4WD with FEL are a couple of features I will put at the top of the list. I have a few friends that have tractors that I plan to contact. I will start talking with the local Kubota Dealer to a sense of what a new tractor with the implements I need will cost. I will keep my eye on Craig's List. I like the idea of a backhoe and a front end loader but that may have to be in the nice to have column for now. The suggestion to protect the driver from branches with a protective cage while bush hogging was a good one. What will be best about having a tractor at my disposal is being able to jump on it for an hour or two when I have the time instead of having to dedicate a couple of full time days when I rent one.
I still welcome further ideas and suggestion.
/ New Tractor or Used #15
I live about 1 hour from you and for dove hunting rights might make a deal to help you plant crop. PM if interested
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
