What's the point...
Status
Not open for further replies.
/ What's the point... #101
Its only good for a coffee mug or water bottle though. Carbonated beverages are flat in no-time though. And it really aint that great for coffee mugs either. I have sacrificed a few to the bushhog:banghead:
Lynch pins dont fall out of it though:thumbsup:
Does it work better with cans or bottles of beer?
/ What's the point... #103
If you get the right size water bottle, they stick in there pretty good!
/ What's the point... #105
****, it's the cup holder thread all over, lol. Next thing you know the safety police will be here pulling you all over for drinking and tractoring. :)
/ What's the point... #106
Like this poor guy?
/ What's the point... #108
I've done 1 1/2" with my LN-25 wire feeder and 8000 watt motor/generator. Lots of preheat and tri-mix. It was on the Z-bar on a New Holland LW130B wheel loader that broke into two pieces. It has held together longer now than it did from the factory.
Back to the bigger topic. I've left before, a dozen or so years ago. I got tired of every time I posted about a failure on a Kubota tractor everybody wanted to take their tractors back to the dealer and get their machine fixed under warranty without it even failing. I couldn't get them to understand that I saw more machines in a month than they will likely ever see, and that most of my customers put more hours on their equipment in a few years than theirs will see in its lifetime. I was also annoyed that more people seemed more interested in where to mount a cup holder on their Kubota than anything else. Thankfully the board grew to include more topics and more diverse membership.
I never had a problem with SA, he always seemed genuine in his critique of my welds.
Brian
Brian you make 3 good points here, thank you. You are right the bigger topic is how things are discussed on the internet, not actual "welding". Every once in awhile there is a response from a pro that is the real deal.
1) A welder fuses metal. There are many techniques necessary. Very few techniques are listed on the outside of the box. Sometimes a few more techniques are listed in the owners manual. It naive to think what's printed on the box encompasses the entire capability of the tool. I understand why they print 3/16" (or 1/4") as the max thickness for a 120v MIG. Anyone remember when all hand drills were called a "1/4-inch drill motor"? This is kind of comical, actually. Especially when 'pros' jump on the bandwagon (not you Brian).
2) High on the list of many TBN members is the desire to retain their tractor's resale value. A forum is the perfect place for them, better than out there putting hours on, scratching up the paint. But so what? It's a hobby. Understood it can be annoying to a pro whose desire is to give a 'real' answer - but it's about the same as internet weld inspectors. They can ignore the serviceability of a weld, which is ludicrous in the real world but perfect for the internet. Many forum members are unable to assess the serviceability of a weld and will admit it. The "appearance thing" becomes quite the conundrum for these fellas.
3) A bully's goal is to elevate himself, he will gravitate towards challenges that he expects to win. But on the other hand, I bet you didn't post any pictures of welds that were serviceable,,,,,, (but you know that in the right conditions, position, access, with more time to prep, higher $bid, etc) you could have done much "better". So what? The job is done and once you have enough experience you know its good.
/ What's the point... #109
Brian you make 3 good points here, thank you. You are right the bigger topic is how things are discussed on the internet, not actual "welding". Every once in awhile there is a response from a pro that is the real deal. 1) A welder fuses metal. There are many techniques necessary. Very few techniques are listed on the outside of the box. Sometimes a few more techniques are listed in the owners manual. It naive to think what's printed on the box encompasses the entire capability of the tool. I understand why they print 3/16" (or 1/4") as the max thickness for a 120v MIG. Anyone remember when all hand drills were called a "1/4-inch drill motor"? This is kind of comical, actually. Especially when 'pros' jump on the bandwagon (not you Brian). 2) High on the list of many TBN members is the desire to retain their tractor's resale value. A forum is the perfect place for them, better than out there putting hours on, scratching up the paint. But so what? It's a hobby. Understood it can be annoying to a pro whose desire is to give a 'real' answer - but it's about the same as internet weld inspectors. They can ignore the serviceability of a weld, which is ludicrous in the real world but perfect for the internet. Many forum members are unable to assess the serviceability of a weld and will admit it. The "appearance thing" becomes quite the conundrum for these fellas. 3) A bully's goal is to elevate himself, he will gravitate towards challenges that he expects to win. But on the other hand, I bet you didn't post any pictures of welds that were serviceable,,,,,, (but you know that in the right conditions, position, access, with more time to prep, higher $bid, etc) you could have done much "better". So what? The job is done and once you have enough experience you know its good.
Shield Arc is gone. Time to do your victory dance and move on. This tireless carping about 110 volt vs. 220 volt welders has been beat to death over numerous threads.
Every time a reasonable thread about welding was started, it took little time before you guys with the torches and pitch forks would show up and crap all over someone else's thread.
Sent from my iPad using TractorByNet
/ What's the point... #110
Let me get this straight Rick, which of these is the "tireless carping, prattling" that bothers you so much that you continue to read and reply?
carp/prattle #1: 120v MIG is worthy of discussion & developement on TBN welding sub-forum
-or-
carp/prattle #2: 120v MIG is NOT worthy of discussion & developement on TBN welding sub-forum
/ What's the point... #111
Neither. They both go flat quickly once opened and stored in the cup holder. Best to finish them quickly.
Yep sounds like an operator problem if it is going flat :licking:
/ What's the point... #112
Little did Arc Weld realize how spot was his naming of this thread!
/ What's the point... #113
Sodo
As far as I am concerned you stand on pretty shaky ground condemning anyone else for bullying on the internet.
I bought a 120v machine and before I used it I asked you for advice because I thought you did some pretty good work with a 120v machine. I admitted I had no welding experience. You yourself told me that what I wanted to do was at the limit of the machine so I took it back and got a 120/220v machine -- primarily on your advice (if the 120v welder says it is at the limit it must be so). Next thing I know you jumping up and down (metaphorically) and very sarcastically calling me a !!!! liar. Made me just step out of the conversation.
Seems pretty hypocritical faulting somebody else's internet etiquette.
Status
2016 Ford Transit 350 Cargo Van (A61573)
2016 Ford Transit...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
121A (A63745)
121A (A63745)
(1) 80" X 33" TAILGATE, APPROX (4) 48" X 60-79" (A64280)
(1) 80" X 33"...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
