Leaking hyd. cyl, 400X Loader
/ Leaking hyd. cyl, 400X Loader
No matter how long or short the cylinder is, it still if FULL of oil. What about my glass of water analogy? Walk me through your logic with a similar analogy.
Cylinders are NOT generally "much" longer than the stroke, and even if they were, it isn't like there is an air space in there.
Draw a cylinder with the dimensions of your choice and work through it...calculate the total oil in the cylinder in 2 different places and let me know what you come up with.
Arlen,
Your illustrations was very good and clearly makes the case that the volume of oil on the rod side must equal the volume on the piston side. I have always been under the assumption that the rod side in fact has more cylinder space to accomodate the volume lost because of the rod displacement. I was not home when I sent my last post but did go to the Hydraulic Surplus ctr website and did my math using ram specs for a cylinder that had a total length that was about 5" longer than the stroke dimension-thereby verifying my theory that the rod volume is compensated by longer cylinder length.
However, when I got home, on Monday I fired up the 4720 and raised the loader to max height.
Extended rod length out of cylinder is about 20+ inches. Cylinder length I believe was about 22"- I didn't write it down because the difference was not enough to support my theory. In fact, the taps for the hoses on each end of the cylinder were around 20"-which further disproves my theory at least as far as JD goes.
Now I did have a conversation yesterday with a buddy who did work as a tech for the largest "green"dealer in MA. He currently is head wrench for a local highway dept and also runs a mobile Farm equipment repair business on the side. His take was seals on their own will cause piston "droop". He also is of the opinion that todays seals are nothing like they were in the "Old days".. I can attest to my experience on IH and Ford TLB from 40 years ago. I recall the packings were heavy andrather than having a flat face, had "v" section-thus they would stack up and form a more positive seal.
In any case, I have a couple of more guys that I have to talk to for a better explanation of the "cylinder much longer than the rod" issue.
Stay tuned. In any case, thx for taking the time to come up with your drawing- I would say that clearly illustrates the boom cylinders on a 400X.
/ Leaking hyd. cyl, 400X Loader #22
Arlen,
Try this:
Raise your loader up, and disconnect the quick connects. Let it sit for a day. I guarantee as sure as the sun will rise in the east tomorrow, your boom will not drift down, even if you removed the seals completely.
I think allot of techs get confused on the difference between the behaviour of bad seals when we're talking retracting, as in the case of a boom, and extending as in the case of a bucket curl cylinder.
You're still not looking at it with the right logic. Even if you come up with a cylinder that has "extra space" it still doesn't matter. You still have a vessel filled with an incompressible fluid. You can't force a steel rod into it without fluid leaving the vessel. In the case of a loader boom valve/cylinder system, that can only happen in two ways:
1: External fluid leaks
2: leakage back through the valve.
Just come up with a cylinder with whatever dimensions you want, and we can work through it. Just remember my glass of water analogy.
While your at it, think about how the REGEN function works on the dump circuit of a loader.
Try this:
Good idea on the disconnects-in the middle of another project (staining house-ugh) will monkey with it next week. And trust me- I agree 100% with you and Mr. Pascal! I'm just having a hard time with that extra cylinder length as in the example I used-
/ Leaking hyd. cyl, 400X Loader #24
Sadly, many technicians in the field are weak on theory. (Conversely, lots of theoreticians don't have much field
experience.) I can recall nearly 20 y ago, I was asking the head service guy at my local Kubota dealer how to
connect up some AUX hydraulics to my first tractor. He was very helpful, but did not BS me with theory he did
not know. Indeed, he told me on one occasion that, "I know this works, but I can not tell you why". I give him
a lot of credit for that.
When it comes to hydraulic seals, modern technology has made some big advances over the "old days". Not
only are there many configurations of piston, rod, and gland seals, there are numerous material types, including
urethane, tetra fluoroethylene, NBR, etc. (Teflon, Buna, Viton, etc). I suspect that back in the 1930s, when
fluid power was young, seals might have actually been mde of leather, as they did for carburetor accelerator
pumps back then.
Anyone interested is invited to look at any online catalog of seals from any big maker out there.
Well Arlen, I followed up on your suggestion, raised the loader and disconnected lines. You were correct-no drop whatsoever! I guess that effectively blows my theory out of water.
Now a new problem, can't hook loader arm hoses up-or should I say one or the other. I imagine this is because arms are "charged" in raised position. Any suggestions? I fooled with this for 45 min tonight, took turns bleeding pressure off by depressing center nub-only thing I accomplished was making a mess- still can't get both hoses connected. Any suggestions?
I have tried with engine on, off. Tried leaving last loader valve position "up", then "down" No difference.
/ Leaking hyd. cyl, 400X Loader #26
A bottle jack and a block or two under the loader should get the pressure off.
OK-willgive it a try in AM before sun hits it.
/ Leaking hyd. cyl, 400X Loader #28
The fact that pressure is building on both ends of the cylinder, with a load, suggests that you do in fact have bad seals
Well I did get it connected-so I thought, started machine, boom control worked, bucket locked! got off and saw bottom right hose (red) was out. I don't have a 400X manual and assumed bottom two connections were for boom. (Bought machine used and never had manual-when I sold my 3320 I gave new owner my manual-figured nothing in loader manual!)
What is proper routing of four hoses?
Thx
/ Leaking hyd. cyl, 400X Loader #30
All raised loaders will do that when you disconnect the hoses, regardless of how good the piston seals are. Theoretically,
if the piston seals are "perfect", the rod side of the cyl will not be under pressure. But, you will find that in the
real world, even a brand new FEL will see pressure on both sides, making disconnected QA poppets hard to release.
/ Leaking hyd. cyl, 400X Loader #31
Little late to the thread but glad you proved the point. Over the last few years I cannot even count the number of times I see seals being blamed by many people for things drifting down.:mur:
As to the lack of lift power, have you by chance put a pressure gauge on it and see if you are even getting to the spec? probably somewhere around 2500PSI?
/ Leaking hyd. cyl, 400X Loader #32
Typical, the green and black are to the lift cyl.
the red is to the head-end of the bucket cyl.
and the yellow is to the rod-end of the bucket cyl.
Thx guys for all your comments, suggestions. The "red" was the last issue-anyway this morning I put a 3 ton floor jack on the cutting edge putting a strain on the curl function. wentback to machine at around 5:30 tonight and it "clicked on" with no strain.
Guess I should get a tech in now to run some pressure checks.
/ Leaking hyd. cyl, 400X Loader #34
You should just get a pressure gauge from Ken's Bolt On Grab Hooks.
I have one and works great. You won't be able to have a tech pull into your driveway for what the gauge costs.
/ Leaking hyd. cyl, 400X Loader #35
arlen4720
Thank you for that link. Excellent video showing the use of the gauge and a good price on that pkg. A few years back I assembled a pressure gauge just for that purpose.
Also glad to get the lead on the other connector parts. :thumbsup:
Well I finally borrowed a good gauge and checked all my ports at the loader quick connects. All four at 2500! So I guess my pump is good? My valves are good? Which gets me back to my original concern. First, my loader arms would drop overnight-my thought I had a packing issue. Arlen's test with the complete disconnect proved that to not be the case.
Second issue. I was of the belief that I was not hitting the 400x's rated lifting capacity. I based this on the fact that I could not get a structure I was told weighed 1200 pds more than 18" off the ground. Perhaps that "1200" pound assembly wasn't 1200 after all.
Next step will be to see just what I can lift using various granite pieces I have (assuming 168 pds/cu. ft.)
/ Leaking hyd. cyl, 400X Loader #37
I am guessing that your 1200# structure might weigh a bit more.
Even with complete disconnect of the loader, The packing can still be bad.
If you want real piece of mind, get a good 3000psi gauge, a few quick connects, and TEE it in inline with the lift port. I did this on my kubota. With a little math you can even get a rough estimate of what stuff weighs. Or get a good idea if you got a "good" scoop of dirt or not.
View attachment 391083View attachment 391084
Thx LD- I hear you on the gauge/"T". I think I'll try the granite blocks first. Just out of curiosity, how can you figure material weight using gauge? Guess says if pump is rated at 2500, and you are moving load with reading of say 1300, load is 1200???
/ Leaking hyd. cyl, 400X Loader #39
Using the gauge is still strictly a guess. Cause the same weight, only situated farther forward, is going to be a different pressure reading.
But I have done some calculations on the geometry of the loader, cylinder size, as well as real world testing. And have figured that 1psi is pretty close to 1# for a load at the center of the bucket. (like a load of dirt/sand/gravel).
It reads ~600PSI with nothing in the bucket. So at 1600PSI, I am lifting roughly 1000lbs.
Again, its just an estimate. Using a bucket tooth or two for a strap to hoist something shifts that load forward, and it isnt 1:1 anymore. More like 1psi will only lift 0.8# or so.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
JMR 8ft Man Basket Skid Steer Attachment (A64553)
JMR 8ft Man Basket...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
