3320 vs. White Oak
/ 3320 vs. White Oak #1
Steve_in_SEMich
Ortonville, MI
Deere 3320 w/eHydro
Needed to take down a large White Oak to make room for our camper and open up the woods a little. Tree measured 34-37" in diameter and will end up making a lot of firewood and few pieces of woodworking projects. This was as far as it would lift the log, and needed 4-wheel drive as the back tires would spin without it. Probably could have used a few hundred more pounds of ballast to balance better, but I only needed to move it 25 feet for now.
Horst forks came in handy again.
/ 3320 vs. White Oak #2
Steve,
I checked a timber weight calculator and it says - Oak, white - 36" in diameter - 431 pounds per running foot. You may be beyond what your unit is designed to lift. I'd be careful - you don't want to break something over a chunk of wood.
/ 3320 vs. White Oak #5
I'd be lost without my forks. Always finding uses for them.
"Grill guard" is a prototype light bar for seeing over the front blade during transport and extra light for night work. My welder friend is good but slow, can't complain 'cuz the price is right. I have woodworking machines and that's what I came up with. Works well, metal version will be a little higher. And as it was said, I are one to.
The diameter of that log was probably closer to 30" than base of the tree at 36" average, and as I only moved it 25' or so on mostly flat terrain, the move went smoothly.
Question though - if the loader can pick up a max load, tires are fully inflated, ballast is sufficient, and the transfer from point A to B is safe, should I not use the tractor/loader at its capacity?
/ 3320 vs. White Oak #7
If the rear tires are spinning, ballast is not sufficient. If most of the weight is off your rear tires, it's almost all on the front axle. I would say you should check the manual for recommended ballast, but for heavy lifting, somewhere around 80-90% of your 3pt lift capacity might be good.
/ 3320 vs. White Oak #8
View attachment 387947 View attachment 387948
That looks like a good candidate for some high end woodworking imo. I would love to have some of that wood to slow dry and work with.
/ 3320 vs. White Oak #9
/ 3320 vs. White Oak #10
Half the stuff I pick up is way to heavy. You generally don't know how much you can pick up until you try it, then if it is to heavy or not maneuverable just lighten the load. If it is to heavy, it shouldn't hurt anything; that's what relief valves are for. My only concern generally is; is it safe or will I tip over. :2cents:
/ 3320 vs. White Oak #11
I have large Ponderosa pine and the weight of a big one ( 34-38 inches) runs about 3200 lbs for a 10' chunk. A 30" x 10' chunk of white oak will weigh just about the same. IMHO, its safer to know your capacity before you try to lift something than to find out by trial & error.
Do a web search for "timber weight calculator" and it will tell you approximately what any type of log will weigh.
A tractor can jackknife faster than you will be able to react if you balance it on the front axle.
I've made a very simple chart which shows the weights of various lengths & diameters of P. pine.
Man, would I like to have a chunk of that white oak - for woodworking. Be safe..........
/ 3320 vs. White Oak #12
Good suggestion oosik
A 30" diam (small end) white oak will weigh at or around 3100 lbs.
A 30" diam (small end) ponderosa pine will weigh at or around 2210 lbs.
A 34" diam (small end) ponderosa pine will weigh at or around 2840 lbs.
Moisture content will be a variable, as well as any variation in wood density as a result of growth rates. The faster grown white oaks will weigh more due to much denser wood than slow grown white oak.
Slow grown Ponderosa pine will have denser wood than fast grown. Tis the opposite.
1994 CUSTOM FAB 94" X 14' GOOSENECK HORSE TRAILER (A62130)
1994 CUSTOM FAB...
2005 Blue Bird BB Handicap Bus, VIN # 1BAKBCKA45F219634 (A61165)
2005 Blue Bird BB...
(2) 13.6-38/12-38 TIRES W/8 LUG RIM (UNUSED) (A62130)
(2) 13.6-38/12-38...
2012 International 4300 Reefer Truck (A63118)
2012 International...
UNUSED MINI HYD AUGER SET (A62130)
UNUSED MINI HYD...
2025 Auger Bit Skid Steer Attachment (A61567)
2025 Auger Bit...
