How often do you check your zerks (aka grease nipples)
/ How often do you check your zerks (aka grease nipples) #21
Ed, I know it is a lot of money, but trust me get a LockNLube coupler for your grease gun and live a longer life. No rotating the coupler, no pulling, no unscrewing the coupler to loosen it, just a joyful greasing experience. You will need an adaptor ( I made one) for those two zerks on the pedal shafts as the lock n lube is too long to get in there easily, either that or trade out those zerks for right angle zerks like they should have been in the first place. I resisted for a long time but the guys kept on saying how wonderful this thing is, and you know what? They were right.
Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine - FREE Shipping & 30 day money back trial plus $3 for return shipping.!: Automotive
http://www.tractorbynet.com/forums/...ssory-your-lock-n-lube.html?highlight=coupler
I have to agree with James on this one. Seems like an expensive toy, but the reduction in hassle is worth it to me, never mind the grease actually going into the fitting.
/ How often do you check your zerks (aka grease nipples) #22
Sometimes I wonder about you guys. I grease my stuff twice a day...once at lunch and once before I load it on the trailer at the end of the day. I accomplish this burdensome task with a hand pump grease gun and a standard coupler...Oh the horror! :eek: ;)
I have had a zerk come loose from time to time. Usually the angled type.
/ How often do you check your zerks (aka grease nipples) #23
Come on RD, cave in and get a LockNLube,, the rest of us have.:)
/ How often do you check your zerks (aka grease nipples) #26
grease the zerks every time I put the unit away for the night ( after every use ) .... sometimes an additional squirt if the unit is being used for long periods of time ...
/ How often do you check your zerks (aka grease nipples) #27
Actually there are 3 styles of zerks (that I know of)
Pipe thread. (and in 1/8 and 1/4 NPT)
Parallel thread.
Press fit.
Also admit that failures are very rare.
/ How often do you check your zerks (aka grease nipples) #28
Parallel thread.
Press fit.
Metric and BSP (British Straight Pipe. That is what is on the Kioti's)
/ How often do you check your zerks (aka grease nipples) #29
I have yet to find a match sold in other stores.
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
