aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 17,540
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I went to hook up the bushhog the other day and I noticed that the deck was sagging in the middle. Took a closer look and the welds broke between two sections. I got it in the shop and picked it up to start cleaning it up and this is what I found:
White lines are where I am going to grind out the weld (or crack) and re-weld. I plan to re-weld the cracked/broken sections, then weld a backer all the way across the front to tie all three sections together like the chain holder does on the back. I have a piece of flat stock (~2.25" x 3/16 or 1/4") that I am looking at using as a backer (shown clamped in place). Should that be adequate, or should I get a piece of angle to go in there?
This will be welded with a 220V AC buzzbox and one of the rods that I have on hand (6011, 6013, 7014 or 7018 IIRC).
Aaron Z
Aaron Z
