Woodsplitter Build (Timberwolf clone)
/ Woodsplitter Build (Timberwolf clone) #61
How does the out feed system work in real life ? I have a tw5 with a home made table like yours and I am thinking of making an elevator or a feed table - just curious how yours has worked .
Splitter season again.
Did a few mods and repairs including installing a new pump and autocycle valve under warranty. I also put additional support for the tank and motor mounts.
Straightened and re-enforced the tube outfeed. Previously it was regularly bent when wood would come off the wedge and catch the edge. The ramp/re-enforcement is made out of 1/4" thick steel
Painted and labeled control levers. This should cut down on grabbing the log lift lever and launching logs into orbit! I hope :)
I also built a 3' outfeed extension. Hopefully this will get spits out further from my work area and allow me to get a bigger mound of splits before having to stack
Both work excellent.
The longer outfeed is a real benefit. I couldnt imagine not being with the lift either.
That said, my next mod will be to make it a chainsaw powered processor like the Wallenstein models. Probably get at that next spring.
/ Woodsplitter Build (Timberwolf clone) #64
Do you have any pictures of you out feed table in use ? or set up on the splitter ??
The outfeed is permanently attached. The far one does fold up when not in use. I will likely be reworking the outfeed tables to have higher sides as part of the conversion to a processor.
About the best I have for in use pics are these:
/ Woodsplitter Build (Timberwolf clone) #66
The yellow thing at the end of the outfeed has to become a 150.00 hay elevator
/ Woodsplitter Build (Timberwolf clone) #67
Nice build Scooby, I like it :thumbsup:
/ Woodsplitter Build (Timberwolf clone) #68
Just picked up my toys to start getting in gear to build "stuff".Love your build and plan on doing my own copy with some changes.Anybody see any conveyor builds ? Thought about picking up an old hay conveyor to save on some fab work and go from there.
6066 (A61165)
6066 (A61165)
UNUSED 2026 INDUSTRIAS AMERICA 750 GAL TANK (A62130)
UNUSED 2026...
2011 Toyota Sienna Van (A61569)
2011 Toyota Sienna...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
