Ford 4000 pouring diesel (I think) from a strange place...
   / Ford 4000 pouring diesel (I think) from a strange place... #41
Strange the clutch wasn't affected - it would have to be soaked with the level of the leak, wouldn't it? That amount of oil and water would slip the driven disk under any load. Must be a good disc in there.
Jim
   / Ford 4000 pouring diesel (I think) from a strange place... #42
i've seen bellhousings soo full of oil it was coning out under the steering box!
   / Ford 4000 pouring diesel (I think) from a strange place... #43
Jim
actually.. wet clutches don't slip so much.. but may grab a bit.. or swell.
remember.. many devices actually USE oil imersed clutches for long life. IE. independent pto packs are usually wet disc.
Folks, I hit a snag in trying to drain the tranny... Went and tried to open the drain plug on the Trans using a open end wrench, and the square bolt stripped like butter. I tried a pair of big vice grips, and no luck. Next step is maybe a small pipe wrench? Any suggestions on breaking the puppy loose? Torch it? There has to be a magic trick of some sort to get this drain plug out...
-- I don't have access to a welder to weld a hex bolt to it.... Found one of your posts, great suggestion, if you have a welder....
   / Ford 4000 pouring diesel (I think) from a strange place... #46
I'm thinking a big VG would be a better choice than a Pwrench, unless you've got enough bolt head to work with.
Big VG really tight, plus about 3' of pipe on the end ? Hands in a position such that you don't punch something that doesn't move, if you manage to break the VG loose, or in half.
Heat on the bolt is usually a good idea.... if there's water in the sump, those threads may be a bit scuzzy. Even a propane torch can be enough to do the trick.
If that doesn't work, try pounding on an almost-fits impact socket, and using your longest breaker bar plus pipe extender.
Rgds, D.
Thanks, will try all the above till something works. A friend of mine offered to let me borrow his cracker box, so if all else fails I will try Sound's suggestion (from another post) of welding a hex over the old stripped out head.
   / Ford 4000 pouring diesel (I think) from a strange place... #48
Hit it with a hammer, not hard enough to break anything, but it can kind of loosen it a little. Then try turning it slightly tighter before trying to loosen it (I know it sounds crazy, but it works!) And yes, if you can heat it a some, do so.
   / Ford 4000 pouring diesel (I think) from a strange place... #49
It has a tapered thread, no sealing surface other than the threads. It may be enhanced with some thread sealing/locking product, so I would attack it with heat. Putting a nut over the stump and weld would be my choice, that make concentrated heat and a new head.
   / Ford 4000 pouring diesel (I think) from a strange place... #50
How bug is the plug?
Usually ford uses some rather large plugs. Like 1-1/2" NPT that have a ~1" or bigger square.
If thats the case those big iron plugs usually arent machined and not real tight on the tolerances for the wrench. And open end wrenches are "springy". I like a good 15" crescent wrench on them. but if already rounded, the damage may be done. I'd opt for a pipe wrench next. Vice grips are worthless IMO
John Deere 825i Gator (A50514)
John Deere 825i...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
Toro Z Master Mower (A50324)
Toro Z Master...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
