JD 6410 SUDDEN SHUTDOWN MID OPERATION
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #1
hounddog1
st. laurent, mb
jd 6410
THIS TRACTOR SUDDENLY SHUTS DOWN, MID OPERATION, WHEN BALING.
FUSES ARE REPLACED, IT STARTS, AND DOES IT AGAIN.
OBVIOUSLY A SHORT, SOMEWHERE.
ACCORDING TO MECHANIC, MAYBE IN THE HARNESS SOMEWHERE.
HAS ANYONE HAD THIS, AND IF SO, WHERE TO LOOK???
THANKS
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #2
1. Welcome to TBN!
2. Please don't type in all caps.
3. Which fuses are being blown?
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #3
Tell the fuse(s) that blew. Then we can help trouble shoot.
IT IS THE FUSE IN THE TOP LEFT CORNER ON THE PANEL, # F 101
SORRY ABOUT THE EARLIER MISTAKE
FRIEDA
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #7
Does just turning the key ON cause the fuse F101 to blow?
How long does it run before the fuse blows?
My guess is the electric fuel pump.
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #8
If it is the fuel pump, I believe he should be able to just leave the key on and take an amp reading, or just leave it on and see if it blow.
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #9
It was just a guess about the fuel pump. I was thinking it may get hot then blow the fuse.
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #10
It's a very good guess.
My point being that just with the key on and the engine not running, the fuel pump should come on. If it does, then it would be easy to take an amp reading, or see if it blows.
/ JD 6410 SUDDEN SHUTDOWN MID OPERATION #11
i have not a clue about your tractor.
a "shop/service manual" for your tractor should give you a full wiring diagram, along with helping you locate your wire harness plugs. along with color coding for the wires. to help you better track down what the 30 amp fuse goes to.
John Deere Home Page Redirect you can get an online parts diagrams and part numbers. but diagrams are most likely pathetic compared to a shop/service manual.
Thanks everyone.
Had the John Deere mechanic come out, and after trial and error:
a wire between the fuel guage and the fuel pump...
Go figure.
thanks again, we are fixed up.
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
