JD 2010 Power Steering
/ JD 2010 Power Steering #1
StevenPaul
Anderson County, SC
John Deere 2010 (Kranky), JD 4500
It started with the hydraulic fluid coming out of the steering wheel shaft. And now this is where we're at.
and here's a closer look at the guts of what we're trying to fix.
/ JD 2010 Power Steering #4
Or fix it with this.
JD 4120
/forums/images/graemlins/smile.gif
Sorry your tractor is broke. Cheer Up. Winter is here and plenty of time to work on it maybe.
We're up and running!!! Thanks to all who helped out. There's a lot of good solid advice in these forums. I thank you, my wife thanks you, my son thanks, our dogs thank you, and my JD 2010 thanks you. Now, to get back out there and tractorize the world!!!!
"It's not the year the tractor was built, but what was built in a year with the tractor"
Steve
/ JD 2010 Power Steering #6
I have a JD 2010, and am experiencing the same issue....hydraulic fluid coming up the steering shaft. What was the solution to your problem? Just replace a seal?
/ JD 2010 Power Steering #7
Might try a PM to StevenPaul, but his activity shows last to be 2009.
There may be others who can chime in and help you too.
The parts breakdown can be found on jdparts.com, if that helps.
/ JD 2010 Power Steering #8
I think you need to replace seal(parts key #9)
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
2008 International 7300 Service Truck with Crane, VIN # 1HTWAAAN18J690230 (A61165)
2008 International...
2018 CATERPILLAR 299D2 XHP SKID STEER (A62129)
2018 CATERPILLAR...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
