Cat D4G LGP, good choice?
/ Cat D4G LGP, good choice? #1
Wnc3
Gold Member
S.E., Texas
John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
I am in the market for a small dozer for road work, erosion control , brush clearing and maintaining creek crossings on our place, not commercial work. When everyone seems to be going to mulchers, I'm looking at a dozer...
I have found a D4G with cab and air, sweeps, window guards, wide tracks and a 5 tooth ripper. It has 3500hrs on it. Any feed back would be appreciated. Cost is 55k.
/ Cat D4G LGP, good choice? #2
If you are mostly operating on firm ground, the LGP, low ground pressure model (wide tracks) is kind of a waste and more expensive to replace. Other than that, or finding a std. u/c machine, it should serve you well. Oh, we'll need some pics you know.:thumbsup:
LGP is popular down here. After a lot of rain, the bottom falls out....southeast Texas. Thanks for your feed back and I'll try and load some pics
/ Cat D4G LGP, good choice? #4
I did just that with an older CAT D3 and enjoyed every minute of the 17 years I owned it.
Ran out of things to do and reluctantly sold it for 2k less than I paid for it.
A good used Dozer in the smaller sizes are hard to come by around here.
Originally, I had planned to rent which wouldn't have worked for me... dozer work is playtime that had to be scheduled around the demands of work and when soil conditions were optimal...
Here is a picture.
/ Cat D4G LGP, good choice? #6
I may be talkin' out of school here...But, I'd check out the under carriage real good. The sprocket in the picture looks to be pretty sharp. Rails & pins probably won't look much better. This is something that would probably have to be replaced right a way.
There's not much worse than having to wrestle the tracks back on a machine twice a day, especially one that you've just paid $55K for.
Good luck, used equipment is a gamble at best. You win some you loose some. Here's to hoping that you win, and if you loose, not too bad. :drink:
Here is the report.
35% left of undercarriage more or less
I agree the sprocket looks worn. Thank for your input.
A full track job is not cheep. I really want a machine with 2000hrs, but this one popped up in my area set up like I want it.
At 2000 hrs there is a whole lot less worn out. I figured I could run it at least 1500hrs as is and do a full aftermarket track job.
/ Cat D4G LGP, good choice? #9
Are you familiar with dozers? I'm im grimes county also and if you have any questions can give you another set of eyes or input.
Brett
Yes, I had a JD 650 in 1994, new. I don't want to buy new again so I'm looking at used. It will be for weekend work only.
/ Cat D4G LGP, good choice? #11
Oh ok. Where at in the county are you?
Brett
/ Cat D4G LGP, good choice? #12
I don't think I would count on 1500 hrs. in my part of the country, just judging by the sprocket I can see. Maybe I'm just hard on them.
/ Cat D4G LGP, good choice? #13
Enhanced a bit:
Bruce
They are segmented sprockets for easier replacement . They did not mention that in the report above, the wear on sprockets. Should I insist they change the sprockets? In a perfect world I would request a complete under carriage, but that is probably $12k
/ Cat D4G LGP, good choice? #15
I'd say that depends on your "horse tradin' skills".
You can always come down in price, you can almost never go up. Same goes for requesting something extra. You might ask for a new under carriage, and be willing to settle for new sprockets. You never know what someone will do until you ask. A lot will depend on how long they've had it for sale, and what they've got in it too.
Was it a rental machine?
No, it was on a ranch. (Which may be worse because pm on some ranches is when it breaks)
The dealer is going to run it through their shop and check some more issues and then I will report back.
Shops down here are back logged and it takes longer than usual to get machines checked out and repaired.
/ Cat D4G LGP, good choice? #18
Looks like a nice dozer.
Mine has the soft cab and sweeps.....I guess in Texas you probably want the full cab? And do you really need the rippers?
Just seems to be a bit high on the price with 3500 hrs a 35% undercarriage, in my opinion.
Do you have any steep terrain? No worse feeling on a dozer than backing out of a pit and spinning a sprocket......:eek:
I don't need the cab, but I want it for comfort and protection.
Don't really need the rippers, but they come with it. I don't think the PO used them either.
Equipment is currently bringing a premium down here.
The dealer that has it still has not put it in their shop to get a full assessment and punch list. They are that backed up. I'm not in a hurry so ill see how it plays out.
I would really rather have a D5 if for no other reason than resale.
