5055e bell housing bolt
/ 5055e bell housing bolt #1
fieldman12
Gold Member
OHIO
2001 New Holland TN70,2003 John Deere 250 Series II skidsteer,1987 John Deere 2155,2013 John Deere 5055E MFWD,2007 Duramax 4x4 truck, 1973 MF 165,Artic Cat 550 Cougar sled
I noticed in the center of the bell housing there is a bolt that more looks like a drain plug. Also there is not paint on the casting around it. This appears to have been done on purpose by Deere. My manual does not mention it anywhere. I know most 2wd tractors have the cotter key there. I saw some wheres on a Kubota forum they use a plug on one model to drain water etc, from. Anyone know what this is for?
/ 5055e bell housing bolt #2
I believe it is a drain bolt. It is on my 2008 5603. Depends on who you ask. I say take it out. The dealer that just replaced my PTO clutch said they leave them out. JD Corp does not say to take it out. I have heard different stories like its to keep water from going up in the bellhousing crossing creeks or rice paddies a feature more needed in other parts of the world.
It can build condensation or collect water from somewhere and rusts the PTO clutch mechanism. I drained about 15 oz of rusty crap water out of mine when I took it out. My PTO started whining and had sticky engagement lever.
/ 5055e bell housing bolt #3
Can you post a pic of the "bolt" you mention?
/ 5055e bell housing bolt #4
Is it pipe plug(parts key 1)?
/ 5055e bell housing bolt #5
My 2030 has the cotter pin. My dealer told me the cotter pin was to keep the hole open. If removed, mud dobbers could fill the hole with mud and close it off.
Yes, it is the pipe plug part key 1. I wonder why Deere never mentions to remove this in the manual at least once a year?
