Anything else to do when changing a head gasket?
/ Anything else to do when changing a head gasket?
I'm not saying keep them out of the rain; but if it's 100 degrees and the grass is four feet tall maybe better planning would be better for both tractor life and owner wallet.
Now, I DO keep them out of the rain. They live in a little tractor house all to themselves. Mr Kubota and Mrs "One-eyed-Susan" Yanmar (she has a headlight missing). In their house they have food (a 55 gal drum of diesel) and a toilet (another drum for waste oil from oil changes). A happy elderly Asian couple. May they live happily ever after -- if they survive their open heart surgeries... :D
/ Anything else to do when changing a head gasket? #62
Very odd about the Yanmar. No thermostat. Wonder how they keep the temp up when air temps drop, they must have a restriction someplace within the coolant system. Short sighted if you ask me and I'd be tempted to redesign it if it were mine.
Anyhow, sounds like overheating is endemic to that model Kubota. I did a quickie web search, top of the list I guess was bearings of the mowing deck!!??? An answer I found I thought worth considering if everything else is correct was injection timing. The writer felt the factory was retarding the timing for one reason or another but stated that after he'd advance the timing there was none zero problems there after. He didn't say how far or give any specs, but talking to a Kubota mechanic may yield some answer.
Don't know why. It what it is. From what I read the older Yanmar engines were very good. I'm glad I have a water pump though.
Yep. I completely restored by mowing deck. I have a thread on it with pics and stuff HERE.
Well, that's cool. Do you have a link to that? Would like to read up on it some. Thanks for looking.
/ Anything else to do when changing a head gasket? #64
I'm sure many/most of you guys are much more experienced with this engine stuff than I and may even be professional mechanics. I appreciate everyone's feedback. But I don't think that I "thrash" my equipment or abuse it. Bush hogging high grass on a hot day is what the tractor was designed to do. Not abuse. We do mow some high grass with the mower from time to time, but if it's too high, we use the bushhog on the tractor. I don't take off boiling hot radiator caps and I wouldn't run an engine designed with a thermostat without one. I don't turn wrenches for a living, but I'm not an idiot either.
For the record, no one here is suggesting you're an idiot, or anything close to one. My reference to thrashing your machine is wrong and could have been better stated as work them hard as done previously. Sorry for the misleading statement.
I think we're all here to help figure out what your particular dilemma is in having three machines suffering 'heat stroke' type symptoms.
Rebuilding any engine without a clear link to what cause/effect are is difficult at best. If there were a cracked head, blown out gasket or similar it might lead to clearer causes, but so far nothing jumps out, at least not to me.
Any further progress on the rebuild?
Just checked with machine shop. Kubota head showed some stress cracks, but they didn't leak. He said that this is pretty normal. Guides were fine. Seals were fine. Did valve job because 2 valves needed it. They have started on the Yanmar head -- cleaned and ready for pressure check.
I have all the Kubota parts cleaned and new parts on order. Need to clean Yanmar parts and new Yanmar parts should be in transit.
/ Anything else to do when changing a head gasket? #66
A cast iron head that shows cracks!!!!!!!??????? And it's okay????
What does everyone else think of that?
On to the timing thing, note I'm not advocating this only that it's something I ran across and maybe worth considering. And I wouldn't do it to one of my machines without first doing a lot more research. But here is the thread; Kubota g5200 overheating - Yesterday's Tractors
OK I think I found that HERE. He said:
"My B2150 did the same thing when new. After replacing the rad, fan, etc. I decided the problem was somewhere else. I found it. Injection timing!! Advanced the timing and it starts and runs better along with cooler running. If you don't know how ,get a good book or have a diesel shop do it for you. I think they run them like that for emissions or warrantee reasons."​
I checked the service manual and it lists the following as reason why the engine may overheat:
  • Engine oil insufficient
  • Fan belt or alternator belt broken or tensioned improperly
  • Insufficient cooling water
  • Radiator net and radiator fin clogged with dust
  • Inside of radiator corroded
  • Cooling water flow route corroded
  • Defective radiator cap
  • Defective water hose
  • Defective thermostat
  • Defective water pump
  • Defective mechanical seal
  • Overload running
  • Defective head gasket
  • Incorrect injection timing
  • Unsuitable fuel used
NOW, on page 1-87 of the Service Manual, it talks about adjusting the injection timing. I don't know if this has anything to do with it because I don't understand what the flywheel and shims have to do with injection timing, BUT, see the three outputs from the injection pump? These were quite LOOSE when I was disassembling the tractor -- like at least 1/2 a turn loose. Given that they are mounted on the shimmed up part, I wonder if this could be it?
He said that it didn't leak in the pressure test. He said that it's pretty normal. Guess he sees it a lot.
/ Anything else to do when changing a head gasket? #71
If those were loose - and I am assuming that these things are the fittings that hard fuel lines to the injectors connect to (picture doesn't say) - possibly a lean condition ?
Haven't seen any pictures of the engine prior to cleaning ... any evidence of fuel leakage ?
/ Anything else to do when changing a head gasket? #72
  • Overload running
IF, you want to get into injection timing we can help you with the understanding on how it works.
In short though, it's just when the fuel flows starts relation to the pistons travel.
What I think the man in the link was suggesting though was that the factory numbers are skewed for one reason or another.
Only if they were leaking fuel.
I don't think it was leaking fuel. Seems like I would have noticed that as much as I have had the hood open while it was running.
OK. Work with me for a sec:
So if you add shims to adjust the injection timing, then the whole Delivery Valve Holder (part 1) will move up because the Delivery Valve Holder screws into the shimmed up mounting plate. The shims are on the order of .005". If the Delivery Valve Holder were loose about half a turn, would that be like adding a few shims?
Here's a video of me pointing at these parts on the engine:
It sounds like there is a cam underneath there somewhere and the shim changes the position on the cam where the injector fires.
See post #73 that I just posted.
/ Anything else to do when changing a head gasket? #76
If there was enough fuel leaking to ****** the timing......believe me you'd know.
When everything is working what comes out of the pump to the injectors is actually a fairly large volume compared to the area it displaces. If that makes any sense.
The injectors open at a high psi, the pump provides that pressure with volume....not pressure per se.
Yes you have a handle on how the timing is set, with shimming of the pump.
Add shims you ****** the timing. Remove shims you advance the timing. OR if you'd rather phrase another way, move the pump away from the cam it pumps later. OR move the pump closer to the cam it pumps sooner.
/ Anything else to do when changing a head gasket? #77
If you're going to go down this timing road.....the first thing to do is check your machine against the factory specs first.
Then you want to make sure you keep track of and if necessary a written record of what you do after that so you can recover whatever you may lose and want back because of the adjustments.
Not necessarily gonna mess with timing at this point. I was mostly curious if part of the problem might have been those very loose delivery valve holders.
/ Anything else to do when changing a head gasket? #79
I'm on my phone so bare with my replies and lack of quotes.
Stress cracks could be considered normal in the pre-combustion chambers which is likely what he was seeing.
Delivery valves being half a turn loose. I'm surpised it would run at all.
The injection timing is likely retarded Kubota cheats toward the retarded side in their spec. from the factory. I typically remove as much as .008" shim to put the snap back in the throttle response and to put it back into spec.
Brian
Dang. Machine shop lagging on the heads. Radiator may have to soak all weekend at the radiator shop. Kubota parts haven't shipped yet. Doesn't look like I'll get it all back together this weekend. I might get the Yanmar head back on and do some other assembly, but I won't be able test anything without the radiator. Oh well, at least the radiator should be clean.
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
