PICTURES ONLY thread
/ PICTURES ONLY thread #221
IMG_1941.jpgIMG_1944.jpgmoving some firewood
/ PICTURES ONLY thread #223
Tell us more about the LED lights please. Where did you find them? What model number are they? Was it a simple wiring job?
/ PICTURES ONLY thread #224
I bought an LED light for use at night when backing up (mainly used in winter while plowing). Bought mine on Ebay for $57. Mine is 21" wide. Its 120 Watt and works very well. I made a bracket to go across the back to mount it on (3/16" angle and some 3/16" flat stock). Also made one for the front and moved the front cab driving lights down onto it. The third pic shows my garage door at night from 24' away. No moon that night, it was pitch black outside.
The only other lights I've added are amber flashing strobes. 3 front and 3 back seen just under the LED light. And for me it was a simple wiring job. Just time consuming to pop the roof top and side panel inside to run wiring and a rocker switch.
/ PICTURES ONLY thread #225
Check out my thread here http://www.tractorbynet.com/forums/ls-tractors/317315-proud-owner-new-owner-manual.html
It was pretty easy only hard part was snaking the wire to feed the relay.
Mounting will all depend on what light you go with.
It was easy with mine I just made 2 L brackets and every thing lined up.
If I was to do it again I would probably bend the bracket up to follow the roof line as it will raise the light up a little and the roof bolts will be easier to access.
With that being said it does not block my line of sight were it is.
/ PICTURES ONLY thread #228
My new R3039 and the 1952 Ford 8N it replaced.
Building a sugarhouse for this winter's maple sugaring
/ PICTURES ONLY thread #229
Congrats. That's a big leap forward in technology.
/ PICTURES ONLY thread #230
Congrats on the new tractor.
/ PICTURES ONLY thread #231
Since this was back on page 4 I thought I better bump it TTT.
It's two months old but hey its a good action shot.
/ PICTURES ONLY thread #232
Some fun today!👍
/ PICTURES ONLY thread #233
Loving this tractor! Doing some grading with my new everything attachments xtreme duty box blade! Highly recommend their box blade!
/ PICTURES ONLY thread #234
CHEERS.
125 HOURS
CHANGED OIL AND FILTER ENGINE.
LOVE THE BACKHOE FOR SKIDDING TREES.
PERFECT SIZE FOR WHAT I AM DOING.
HERE'S SOME PIC'S
cHEERS
GOTTA LOVE TRACTORS
MY BACKHOE IS THE BEST TREE PROCESSER.
CHEERS
/ PICTURES ONLY thread #235
Wow!! What a beautiful piece of property, very nice!!!!!:thumbsup:
/ PICTURES ONLY thread #237
You were right Bob ! This thing is a money pit . I had to flatten out some ground behind the house to put the new enclosure for the tractor . It will do for the next 2-3 years until I get a Garage up .
Anyway , it gave me a good reason to put a little scrape in the ground out back . :)
/ PICTURES ONLY thread #239
Thanks very much.
I have been working on this property for 20 years.
I was 40 years same job, 20 years here and it was my birthday.
The tractor was my present.
Only regret is I didn't have one sooner.
Sure beats an atv all to heck.
Cheers.:drink:
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
John Deere Z994R (A60462)
John Deere Z994R...
JOHN DEERE 3 BOTTOM PLOW (A63745)
JOHN DEERE 3...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63118)
2011 Peterbilt 6x4...
