Anyone have a German-made 1020?
   / Anyone have a German-made 1020? #1
tractorsrule
Ostrander, ohio
JD 2305
Hello all. I have a 1020 that was made in Mannheim, Germany with a serial number of 020238. It is a 3 cylinder diesel with a loader. I was told that it was built in 1969. It only has 1 key and it is very strange looking. The local JD dealer told me that they had never seen a key like that and many parts for the German made tractor are different than the Iowa made ones. Anyone familiar with these tractors? It looks the same as all the rest. I will be needing to have some leaks fixed, etc this coming winter. I hope that the hydro pump in the front of the tractor can be rebuilt with new seals, because it is leaking. I would really like to have a spare key also. Thanks
   / Anyone have a German-made 1020? #2
Here's the ign key for your tractors SN L22964 Key - KEY ADD 12.40 USD
RE228042 Hydraulic Pump - HYDRAULIC PUMP, HYDRAULIC PUMP OVER View/Update 43.99 USD
   / Anyone have a German-made 1020? #3
I vaguely remember changing my ignition switch to one I bought from NAPA, solved that problem. Your dealer should have most of the parts you will need for this tractor as quite a few of these were sold in the USA. These were built for the US market so nothing to be concerned about as far as being oddball.
Wow. Good news about the pump and tractor! I will post a picture of the key. It must not have the original ignition switch, even though it looks very old. I saw a rebuilt pump on Yesterday's tractors for over $1000!
   / Anyone have a German-made 1020? #5
If it were me I would check the hydraulic pump for pressure and flow to get a better diagnosis of it's condition. While it may need just seals it could need a full overhaul which would be more money for sure. Often the seals go because the tolerances aren't close enough to seal off the fluid.
   / Anyone have a German-made 1020? #6
Sorry BUT 1020's built in Mannheim were built for European sales not USA. 1020's built for USA sales were built in Dubuque,Ia.
   / Anyone have a German-made 1020? #7
All 20 series utility tractors for Canada market were built in Mannheim.
   / Anyone have a German-made 1020? #8
My mistake, learn something new here everyday. I assumed that the 1020 builds were similar to the 820 builds in Germany.
   / Anyone have a German-made 1020? #9
Maybe so but I sold 1020's when they were new and the ones sold new in Texas were built in Dubuque,Ia not Mannheim. The 1st JD tractor built in Mannheim and sold new in a Tx JD dealership was a 3 cyl 820 followed by the 3 cyl 830 then followed by the 40 series
   / Anyone have a German-made 1020? #11
I've never seen anything like that key. I would want a JD ignition switch and key.
   / Anyone have a German-made 1020? #12
I have a 72 german built 820 which is a lot like the 1020 and my original key looks nothing like that. I have much newer tractor, but I always jump on my 820 first, what a machine.
   / Anyone have a German-made 1020? #13
cartod, that 820 looks great and I remember when I finished refurbishing my '73 model about 15 years ago. Sure was proud of the way it turned out. I added the canopy top a few years later and that worked out great for the sun here in the southwest.
Curious how it is working out with the land plane? I had to think about it but I don't recall trying mine out with the 820.
   / Anyone have a German-made 1020? #15
The Mannheim 1020 and the Dubuque 1520 are the same tractor wearing some different external pieces. Europe mandates a parking brake instead of a "parking lock" etc.
The 820 and all but the last few 830's were a low priced version with an open center hydraulic system.
   / Anyone have a German-made 1020? #17
Key in photo fit these JD models. Part number is L22964. IIRC one pushed key in to turn on ignition and pulled out to stop ignition. These early models also use elect fuses that resembled fuses used in VW Bugs
4107 - 3120 Tractor - 12May11 ( FR DE IT ES SV )
4114 - 820 Utility Tractor (North American Version) - 16May11
4152 - 1020, 1120 Tractors - 12May11 ( FR DE IT ES SV )
4163 - 820, 920 Tractors - 12May11 ( FR DE IT ES SV )
4164 - 2020, 2120 Tractors (European Edition) - 12May11 ( FR DE IT ES SV )
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
