Cultipacker Build
/ Cultipacker Build #1
Baby Grand
Elite Member
Windsor, CT.
Kubotas: L3240GST B2320HST B5100D & G5200H
Have been working on this project on and off for several months. The Plant Manager wants to plant buckwheat in our fallow garden plots and supported my effort to get it done and out of the garage, where it's been taking up far too much space.
Welding main frame complete, axle, pillow block and wheel assembly installed.
Fit up of the hitch structure commences:
Welding the hitch structure commences:
Assembled and inspected:
The Plant Manager approves after sea trials:
/ Cultipacker Build #3
Nice job, looks very good!! It's always a bonus when the "Plant Manager" approves!! :)
/ Cultipacker Build #4
Great job!! Not to be picky though, but technically that is a packer. A cultipacker would have two axles,with rollers,with a gang of spring tooth tines centre mounted.
Nice work.
Terry
/ Cultipacker Build #5
Nice job. When in doubt, build it stout:laughing:
/ Cultipacker Build
Thanks for the kind words!
This weekend should be see it's first real workout, planting some buckwheat.
Nice work.
Terry
So it's just a "packer"? Dang.
Too late to change the title.
But I already learned something today!
/ Cultipacker Build #7
[ So it's just a "packer"? Dang. Too late to change the title. But I already learned something today![/QUOTE]
Don't worry. A cultipacker can be your NEXT project. :)
They were made by John Deere. In my area the equivalent Brillion Pulvimulcher was more common.
Terry
/ Cultipacker Build #8
Your original post is correct. It is definitely a cultipacker. Look up cultipacker on the internet of go to Sweet Tractor Equipment. The one with spring teeth is a cultimulcher
/ Cultipacker Build #9
This is all true. As far as I know John Deere originally coined the term "cultipacker" and indeed has spring tines. The term has probably become a generic one by now. I have the Brillion version of it (pulvimulcher) as well as the Brillion packer like the excellent project of the OP.
The spring tines would be the "culti" part of the cultipacker. Maybe...? :)
/ Cultipacker Build
Tilled, sowed buckwheat & packed Sunday.
Got some rain Monday.
Now I wait to see how well it germinates ...
/ Cultipacker Build #11
Great job. Idle curiosity, how much do the rollers cost in USA?
In the UK that implement would be known as a Cambridge Roller. The rollers are usually toothed as your are but sometimes they have a central raised section. The latter leave tiny furrows that seed broadcast after rolling will mostly fall into rather than the "pockets" created by the toothed rollers. No doubt there have been many arguments as to which is best for different crops.
/ Cultipacker Build
The rollers were $8.49 a piece plus shipping from AgriSupply.
/ Cultipacker Build #13
Great job. Idle curiosity, how much do the rollers cost in USA? In the UK that implement would be known as a Cambridge Roller. The rollers are usually toothed as your are but sometimes they have a central raised section. The latter leave tiny furrows that seed broadcast after rolling will mostly fall into rather than the "pockets" created by the toothed rollers. No doubt there have been many arguments as to which is best for different crops.
You are right about that. If used AFTER broadcast seeding you will note that germination will occur best in the indentations created by the raised centre sections because of capillarity and better seed to soil contact. Some farmers had their own rollers cast with a cross hatch pattern for the rear press axles of their seed drills to supposedly facilitate better seed germination.
I experimented one year by setting the seeder at half seed rate and making two passes with the second pass slightly diagonal to the first. I achieved a slightly better germination rate but felt it wasn't worth the extra time and fuel. This was for a turf grass crop, and on peat soils tire track depressions are always a problem
On smaller plots one could consider this option.
Terry
/ Cultipacker Build
... looking good ...
/ Cultipacker Build #15
... looking good ... <img src="http://www.tractorbynet.com/forums/files/build-yourself/382317-cultipacker-build-p7100625-1024x768-jpg"/>
Good timing with the rain on Monday:)
Terry
/ Cultipacker Build #16
Thanks, even with the numbers needed it works out at a very reasonably priced piece of kit.
Big Barn, Yes, I knew about using them after sowing too. In that case, for small seeds, my own inclination was towards the completely raised centre. Others disagreed.
/ Cultipacker Build #17
Looks real good and appears to do the job well too. I looked up the rollers on Agri Supply and see these are lighter in weight than I expected.
/ Cultipacker Build
Thanks! Yes, the wheels are somewhat light, thin castings. If I could have sourced affordable Brillion type wheels I would have gone that route. To make up for the lack of weight, I used 2x2x1/4" wall for the frame and a solid axle instead of pipe. I think I may add some ballast tanks to it so I can add additional weight, if need be.
/ Cultipacker Build #19
A question for those with experience of using similar equipment. How heavy do you think they should be? I have no figures of weight of modern ones (could probably find some with a bit of Googling) but the few I knew of in use on farms in the UK were modified single horse drawn ones and easily pulled around into position by a man for pinning to the tractor drawbar. Most people I knew also had a flat roller if compression was needed, and these could usually be ballasted.
The Cambridge rollers were pre rotavator days and used only to fine down a seed bed or, as discussed above, pre or post broadcast sowing.
/ Cultipacker Build #20
I was expecting about 150 to 200lbs/ft to get a firm compaction. I use light plastic water filled rollers that are 120lbs/ft and have a new build for a steel and concrete roller that is 375lbs/ft.
2002 FORD E350 CARGO VAN (A66091)
2002 FORD E350...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
Vibratory Plate Compactor (A64553)
Vibratory Plate...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
