Help - mouse nests in cab AC
/ Help - mouse nests in cab AC #1
Michael_Porter
Southeast Iowa
I have a JD 3720 with a cab. This year I had a problem with mice getting into the AC vents and leaving a smelly mess that I can't figure out how to completely clean out.
The areas I don't know how to get to are at the top-back of the cab: the evaporator coils, the drip pan, and probably in the fans too. I have removed the outside filter and can see the debris in the drip pan, but the opening is so narrow, I am able to only partially clean it.
I have removed the covers and foam filters inside the cab, on the back, inside top. That allowed me to bend the headliner down enough to get in part way to the vents leading from the evaporator, but not far enough.
I'm considering removing the outside roof of the cab because it seems like it has accessible bolts all around, but I don't know if that will get me access or is the best way.
Any suggestions would be welcome. Someone else must have had this problem.
/ Help - mouse nests in cab AC #2
Can you get in there with a pressure washer nozzle?
Not much worse than a smelly mouse nest. And hope they didn't chew any wires off to make it more "worse".
Spraying in some bleach may help with the smell.
And a good supply of mouse poison available to the critters will help in your future. Works for me.
/ Help - mouse nests in cab AC #3
shop vac, with some duck tape and a smaller hose? to vac / blow out?
a electrical fishing wire, to rough out wire in homes before paneling and like get put up on the walls. not a big fan of "hooking stuff" but perhaps a "solid core" wire, say 14 gauge, soft enough to pend a hook on, and if ya get it caught on something, a little pull hopefully undoes the hook to let it slide back out.
for pulling wire through pipe, have always tied a rag onto some string, grabbed some duct tape and another rag and shop vac and blown rag/string through pipe. and then if needed sucked the rag/string rest of the way through on the other end. just make sure you have the "filter on" if ya suck it through, so rag/string doesn't get caught up in the shop vac motor.
once string is pulled through pull a little bit bigger string or wire through, and then pull addition rags or like through *shrugs* not sure if i would put a big old wad of rag on. and try and pull through. but maybe a handkerchief or cut up portion of one, and just knotting and taping one corner to the string or wire. tape is more acting like a funnel on front side of the knot, so as to keep the knot from getting caught up on something and guide the not through the ducts.
not much luck for nice and clean, but if not a lot of turns and bends, i have taken electrical fishing wire, and put one end into a drill, and gave things a few turns to twist things around inside the pipe. have done this to clean out some "see through / clear" 1.5" hose that is on a display aquarium/pond and getting rid of algae that grew on the inside of the pipe.
if mouse or like has died in your duct work, about all i can say is give it some time to decay. as in a couple months. and smell will go away. it is by no means the greatest thing in the world. but *shrugs* if you can leave the doors and windows open to help air the cab out. so the smell doesn't creep into the seat cushions...
It's a good suggestions but the pressure washer has two issues.
1. The pressure will bend the very delicate evaporator coil fins.
2. I don't know where the water will go that exceeds the capacity of the drip pan and if it will damage anything, like a fan motor. if anyone has done this without causing damage, please let me know.
On mouse poison:
I have had bad experiences with mouse poison. It's a much worse smell than a urine-soked mouse nest to have a dead mouse decaying where you can't reach it.
/ Help - mouse nests in cab AC #5
It takes two people to lift the top off of the cab but that is what I would do. Get everything cleaned up and examine the cab seal before you replace the top. I don't recommend you breathe that crap (literally). I personally am not into it but this might be a good time to add some tunes or XM while it is opened up.
Are the bolts that are visible around the edge of the top of the cab all that have to be removed for it to come off?
/ Help - mouse nests in cab AC #7
I have had bad experiences with mouse poison. It's a much worse smell than a urine-soled mouse nest to have a dead mouse decaying where you can't reach it.
I find getting the poison out before they nest will cause them to die from where they came, as they go looking for places to nest, find food (poison) and take it back. Don't have a problem of them dying and smelling that way.
Good luck getting it cleaned up.
I'm posting my experience with this in case someone else has the same problem with their JD 3720 cab AC.
If you have mouse smell coming out of the cab AC, the only way to fix it is to remove the roof of the cab so you can have access to the evaporator, fan motors, and every place where mouse detritus may be in the air flow.
I highly recommend you do this in a covered work area. The job may take longer than you expect, and it's nice to work in the shade.
Removing the roof
Thirteen bolts hold the roof on. They are easy to access and remove. Two of them require you to remove the two rear lights to get to them. Each light is held on with two bolts, and its wiring harness has a simple snap connector.
After the bolts were out, my roof was slightly stuck, but it came free with bit of encouragement from a small pry bar. I started at the back and worked gradually around the cab until the roof was not stuck anywhere. Doing this did not damage the seal.
To remove the roof, you want to lift straight up. The roof has 13 bolts integrated into it that stick down, and you want to prevent them from tearing up the seal. It takes two people to do this safely, and you will each need a stable step ladder.
I was lucky because I had a winch and pulley that I had rigged up before to assist in loading a cargo carrier on my car roof. I ran an adjustable strap across the cab roof and placed its hook ends under the edges of the roof. The winch cable hook went under the middle of the strap.
While my wife cranked the winch, I easily guided the roof bolts out of their holes. I found that the roof balanced perfectly if the strap was just a few inches back of center. With the roof in the air, I backed the tractor out and lowered the roof to the ground. The winch was even handier when I replaced the roof. It allowed me to to guide the bolts into their holes without damaging the seal.
Cleaning out the mess
First I started with a shop vac. The cab has an inside roof structure that you can set a shop vac on. I scraped and vacuumed up as much detritus as I could. I also used a computer vacuum kit, which attaches to a regular vacuum hose but necks down to a smaller hose and cleaning tools. This let me reach into narrow places and crevices.
Then I used high pressure air to blow out areas I couldn't get with the vacuum. I wore a dust mask and goggles and was glad that I did.
Now came the difficult part. There was no way to get to the evaporator drip pan, and it was an especially dirty area. It needed a good flushing out, and so did everything else up there if I wanted to really fix the smell problem. But right behind the drip pan, on both sides and less than an inch above it, were the two large return air vents that open into the cab. The system is designed to handle the drips from the evaporator coil, not the amount of water needed for a proper flushing.
My solution. I went inside the cab and removed the two plastic return air grills and their foam filters at the back top of the cab. I could then pull back the headliner enough to stuff towels inside the return air openings. I went back on top and pulled the towels up and stuffed them back down until I was sure I had the openings blocked. Inside the cab, the two towels hung down like giant wicks. As a extra measure, I put two buckets below them. The tractor seat arms did a good job of holding the buckets in place.
Now I was able to move the tractor outside and use my pressure washer to clean the evaporator coil, drip pan, and all the surrounding areas that were contaminated. My wife kept watch inside the cab to stop me in case the towel system got overloaded. It worked. I think a steam cleaner might be a better option for this job, but I didn't have one, and I did have a pressure washer.
Next, I used a foaming AC coil solvent on the evaporator, the non toxic kind, designed for this purpose. And followed that with another pressure washer rinse. This left the evaporator coils and fins nice and clean, maximizing the AC system's ability to cool.
Then a final shop vac go over, sucking up as much of rinse water as possible from all areas. I didn't want to leave any dissolved solids to dry and be a source of odor.
Extras
Since I had the top down, I could check all the wiring. I did find one wire where the insulation had been chewed off by the mice. I taped it up.
And, probably more symbolic than practical, I sprayed some air freshener on the evaporator before replacing the roof.
I decided it was also the time to spring for a new AC air filter.
Replacing the roof
As I said before, I had a winch and pulley system to make the job really easy for me. The goal is to get the bolts to drop into their holes without dragging them across the roof seal enough to tear it up. If the seal is broken, replace it. The air flow system for heating and cooling depends on it to work properly.
After the roof is in place, you need to push it down all around so the bolts will reach far enough to start the nuts. I replaced the nuts in two stages. I started them manually, and then went back with a cordless screwdriver to tighten them up. When starting them manually, I still used my socket extensions, but I turned them by hand, like a handleless screwdriver. This worked well, especially when I couldn't see what I was doing and had to go by feel.
Prevention
How to keep this from happening again? My homestead is surrounded by wild habitat and teems with mice. I don't have a proper structure to keep the tractor in. I've tried using mouse traps in the cab, and that catches mice like crazy, but it's too hard to maintain. Also, it finally struck me as silly to be setting up something that would lure mice into the cab. I don't like poison because of its unknown downstream effect on the local food chain. For example, my beloved dog spends a lot of time outdoors hunting mice.
The local JD dealer recommended some Fresh Cab botanical rodent repellent. It contains Balsam Fir Oil and doesn't smell too bad. I'm going to try it this winter.
Thank all of you for your help and suggestions.
Michael
/ Help - mouse nests in cab AC #9
Mouse poison - be SURE to get a brand that contains Warfrin. The mouse will exit the tractor cab for the poison and then seek water. Help them by placing a pan of water on the ground away from the tractor. Only use poison if there are no dogs/cats in the area.
/ Help - mouse nests in cab AC #10
sounds like you had one heck of a day to get that all dealt with! or was it a weekend over haul?
More than a weekend. My narrative sounds like it happened in one workflow. In fact, I was stumped for a couple of days before I came up with the towel method to block the return air vents so I could pressure wash. I tried several wimpy rinses with just a garden hose, monitoring and stopping the rinse before the water overflowed into the return vents, but they just made mouse poo soup.
/ Help - mouse nests in cab AC #12
Spray the cleaned area with a household bleach/ water mix and it will kill any urine smell/odor left by the mice, and I've found that doing that keeps them from coming back... either from not smelling their previous visits or not liking the "clean" smell of bleach.
Had a terrible time with them coming back to a lawn tractor time after time, and once finally cleaning it up with bleach, never another problem.
Found the same "habit" with racoons that found the deck to be a good toilet location. Scrubbed down and used bleach, they stopped.
A followup on my tractor cab mouse problem. This winter I used Fresh Cab Rodent Repellent pouches I got at my John Deere dealer. I put a pouch inside the AC vents on both sides of the cab and also a couple in the general cab area. I refreshed them several times during the winter. This seemed to keep the cab completely free of mice for the whole time.
This is the first thing I've tried that really worked. I'm going to do it again next winter and will post my experience again.
No poison. Not a bad smell. Simple and easy to use. So far, so good.
Another follow up. I used the Fresh Cab again this winter (2016-2017) and had another no-mouse success. Looks like this product really works.
/ Help - mouse nests in cab AC #15
Darned varmints! I had mice nesting in the air cleaner housing of both my Ford Ranger and Ford Fiesta! I repaired the garage door bottom seals. Plugged in some of them sonic pest chasers into the outlets. And set out lots and lots of traps near likely entry points. And I caught lots of mice in those traps. Then found no more nests . :)
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
(4) Ratchet (A65583)
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
