Attaching Front End Loader...
/ Attaching Front End Loader... #1
BCBSLICK
CLARION
BX2670
Is there a trick to attaching and disconnecting the front end loader on a 2670?...
I seem to have nothing but trouble
I have the loader setting on fairly level ground. I line-up as near perfect as I can when I drive the tractor between the loader arms
I do notice that the hoist cylinders are not always at the same place熔ne push rod will be farther out than the other. I can sometimes manually move it to equal the other side
I almost wonder if something is bent or completely out of alignment
The tractor is new and I have had problems from day # 1
Any thoughts?...
Thanks?CB
/ Attaching Front End Loader... #2
Bump up against the one that sticks out the most, & as it goes in the other will come out.
I doubt anything is bent. With a little practice, it will become easy-peasy.
/ Attaching Front End Loader... #3
For a newbie like I was several years ago, it takes some practice to get it down. I'd re-read the owner's manual as to the procedure. The other "trick" is when the hydraulic pressure on the tractor side doesn't allow the lines to be reconnected because there is pressure in the system that won't let you seat the connectors. In that case one has to relieve the pressure my pushing the center of one of the lines for relief
Cheers,
Mike
Cheers,
Mike
The pressure thing I figured out--called the dealer...
I now have a piece of wooden dowel and push, sometimes tap, it in against the nipple if it won't connect. Oil does get all over the place--not too cool of a setup...
So far, the loader has not been user friendly. But, when it is attached, I do like the work I have done with it...
Thanks...BCB
/ Attaching Front End Loader... #5
You mentioned "fairly level ground"... um... perfectly level ground is better! and Hard ground like a concrete driveway is better yet. And making sure the loader is settled, bucket level on the ground, and all pressure relieved by moving joystick to all positions, multiple times before removal.. If the loader settles any at all after you remove the hoses it will be more difficult to remount the loader. Practice helps a bunch.. You should take it off and back on each day, until it seems easy to you. (easy for me to say huh?)
/ Attaching Front End Loader... #6
What like2wheel said, just move up to the one sticking out and move the lever, the pressure will move the other out to come in contact. All it takes is a bit of practice. The loaders on our BX2660, L5740 and M8540 all work the same and change out quickly once you do it a few times.
/ Attaching Front End Loader... #7
Absolutely, correct! I was taking my loader off and on with nothing but sand, gravel and stone, allowing things to shift. Now I have a dedicated concrete pad to drop and install the loader and backhoe and it makes a world of difference. I put my loader and backhoe on today after mowing yesterday in less than 10 minutes for both. Life is good with a concrete pad...:laughing:
1st pic is what I have now and 2nd is what I had before... a lot easier!
Yea, I agree with the concrete pad...
I have that in a garage at my residence, but at my other property, it doesn't exist...
That is where I used the loader the most...
Maybe a good sheet of 3/4" plywood?...
BCB
/ Attaching Front End Loader... #9
BCB
Even with the plywood loading was sketchy...although I had just half inch plywood...
/ Attaching Front End Loader... #10
I agree with the others in that "fairly level" ground just won't cut it. A pad makes a world of difference.
/ Attaching Front End Loader... #11
Agreed, concrete is preferred, but I've taken all mine on/off in rock or dirt as well by using a board, tree limb etc. if needed, just takes a bit more practice.
/ Attaching Front End Loader... #12
I stored mine on a relatively flat section on lawn last winter with no real issues. I just put a couple of one foot square pieces of plywood under the rear feet so that they wouldn't sink in. Practice is the key, once you understand the process well it doesn't take much time or effort at all.
Sent from my iPad using TractorByNet
/ Attaching Front End Loader... #13
... but at my other property, it doesn't exist...
BCB
Take the time you'd spend on laying down plywood to use your new tool to make a level spot... you need the practice and you'll end up with a more permanent parking spot for the loader. The things you have described: trying to park the FEL on "fairly level" ground, leaving pressure in the FEL lines, loader not user friendly... these are all pretty common new user issues. Goodness knows I went through those years ago, along with other learning experiences, so take heart that some persistence and practice will make you into a pro soon enough. These things do demand some level of mechanical horse sense but you eventually figure out ways to use finesse instead of reaching for the sledgehammer.
Remember there is no such thing as a dumb question or problem. There are a bunch of folks here that will offer helpful advice.
/ Attaching Front End Loader... #14
I took mine off once on "level" ground and it rained. The feet sunk in and it was a pain. Concrete or it stays on.
/ Attaching Front End Loader... #15
For sure concrete pad is the best;if not take off under a large tree limb so you can hoist if needed.
Well, guess I'll just have to deal with it as I sure ain't a gonna pour a concrete slab!!!...
I think a 3/4" sheet of treated plywood with a 2'x4' frame under it just to keep it up off of the ground--help prevent rotting...
Level that and make it stable on the ground...
Then I can put it in a storage shed at the end of fall...
I then let the loader on all winter to do snow removal...
I've seen people let them attached and mow, but the property I mow would be impossible and dangerous to say the least...
There's a lot Kabota doesn't tell ya about much of their stuff anymore...
Thanks...BCB
/ Attaching Front End Loader... #17
Thanks...BCB
assume any sort of hyd cylinder will move. and something will shift / sink on you.
if ya got a tractor, and PHD (post hole digger) drop some taller posts into the ground, wide enough to drive tractor through with some extra inches to spar, and then put a 4x4 or something across the top of the poles. and drop some chains down, or like.
curl the bucket, so it is upside down (so water does not collect in the bucket) position some concrete blocks so bucket doesn't sink into the mud. and away you go.
were the FEL arms attach to tractor, with them hanging by some chains, you can swing the fel arms around some, and if you have a chain hoist or pulleys/rope, you can adjust height.
if you have quick disconnects on the FEL arms, get yourself some short hoses, to act as extension hoses, for hooking up, so you can move the hyd cylinders some if need be.
was lucky a couple years ago, and found some new cherry pickers for little over 100 bucks each. you might be able to drop some posts down, remove the longer front legs from the cherry pickers and mount them to some posts. harbor freight i think has some cranes/lifts for trucks or trailers that might be cheaper you could mount to some posts.
if you are going to build a wood platform, for the FEL, turn it into more like a skid able pallet. so you can toss a couple chains / cables / rops. or use pallet forks, to move it.
cost of plywood and some 2x4's and screws does add up quickly.
ya got a FEL and general duty bucket, so clear out some sod (grass) and level it out, and drop some 2x4's for side frame work, and either buy a 2 bag cement mixer, or higher someone to drop some cement, or rent a concrete trailer with pre mix already to go.
what ever works for ya, remember ya gota mow, and weed eat around all the stuff *arghs*
/ Attaching Front End Loader... #18
When relieving pressure on the hoses,put a rag over the fitting first.You make a lot less mess and it is safer.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2015 Ford F-250 Ext. Cab Auto Crane EHC-32 1.5 Ton Crane Service Truck (A61568)
2015 Ford F-250...
2025 SDLANCH SDLC2030GT Heavy Duty Greenhouse Tent (A60352)
2025 SDLANCH...
2013 Lincoln MKZ Sedan (A61569)
2013 Lincoln MKZ...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
