Best drillbit for steel
/ Best drillbit for steel #21
Chicago-Latrobe makes premium drills. Size your pilot drill a fraction bigger than your 5/8" drill's web thickness.
Clamp the crap out of your work piece. Get you some water based coolant and go to town. Don't overforce the feed, yes push on it so the drill doesn't rub, but don't hang your body weight on it. The corners of the cutting edge will wear first. Don't try to drill too much on each peck. Chipping usually occurs when you come back down on a chip left in the hole from the previous peck. Let the coolant keep the drill cool. Run about 30 surface feet per minute on a manual machine with coolant.
An iron worker hydraulic press will look mighty fine after your first hundred holes.
I hate hand sharpened drills because I'm spoiled. :)
/ Best drillbit for steel #22
I too am in the camp of not having much luck with hole saws. Especially for a measly 5/8" hole. And especially in thicker stuff.
No way would I want to use a hole saw in 1/2" + material. Especially for holes under 1" diameter. But then again, I have always had access to good drillpresses, mills, lathes, mag drills, etc.
The OP is talking a 5/8" hole in 3/8" steel. Not sure bout a hole saw, but a with a 1/4" pilot and a good 5/8" twist drill, should take no more than about 20 seconds to make a hole.
LD, I am totally in line with you on this. Hole saws for me have always been large diameter and in wood! The cost of a twist drill is much less. Use oil and slow speed and save your money on a hole saw. My :2cents:
/ Best drillbit for steel #23
I've had pretty good luck with hole saws. Chewed through 200-feet of rock with this one. But it had a 750-HP diesel engine turning it. :laughing:
So... First, thank you to everyone so far. Lots of great info.
As an update to the project, I was wrong. the holes needed to be 3/4 (Caught this before I drilled) and my steel is more like a thick 3/8" but my drill press runs too fast (500RPM on slow side) and the throat just didn't have the throw I needed. So I went with my large Milwaulkie Hammer Drill. Works like a charm, except for those magic moments when the bit catches and it is ripped from your hands, usually smacking you in the jaw as a friendly reminder to who is actually doing the work. Oh, I went with the normal high speed cobalt drill bit.
It brings me to my next series of questions. I want to get a speed control. JJ posted a link to a few and I see no reason either my drill press or my hammer drill would not run with this.
Second, and more importantly, how often do you oil? I figure these holes are taking me 7 to 10 minutes to drill but I have not timed them. I figure I am running the drill as slow as possible so not sure what that is but it is not the full 500RPM and it is not crawling. Maybe 200RPM max? I oil once every 30 seconds, a few dribbles down to fill up the hole. If I see smoke I stop, oil up and continue (Don' see smoke very often).
I ask all of this as my one neighbor erects steel buildings. He is pretty ruthless. Grabs a bit, slams pressure on it and maybe some oil if he is feeling generous. I think he has guys sharpening bits so longevity of a bit isn't foremost on his mind, more getting the holes in and building erected.
/ Best drillbit for steel #25
High speed steel bits for mild steel. Cobalt for stainless steel. Cobalt is very brittle and chips easily. Titanium nitride is just a coating. Works great until the coating wears off. And that doesn't take long. When the titanium nitride wears off it's just another high speed drill bit. Carbide tipped for cast iron and concrete.
2nd. I also like split point bits just to confuse you further.
/ Best drillbit for steel #26
Just a note about annular cutters.
I like the annular cutters. Hougen for example. But I typically use an 18v drill, and with an annular cutter you don't have to push so hard, and you're not turning the entire plug into chips. So you can drill many more holes (by hand) with less battery power, and less effort. They are expensive, ($25 each) but very nice and they cut fast. Also they make a round hole (as opposed to starting triangular and eventually getting round if the material is thick enough). Be sure to check the depth - the set that I have cannot cut all the way thru 3/8" material, it has a depth limitation.
I've used the standard "hole saws" too, the kind with a pilot drill that you can get for about $8. These work OK for a 3/4" hole if not too many of them. The hole size comes out about 1/32nd over. $8 is not much for a 3/4 holesaw, they are a reasonable alternative, and also can be used with 18v. I drilled twelve 3/4" holes in 3/16" steel with one holesaw and its still sharp, not bad for $8.
/ Best drillbit for steel #28
Not using a pilot hole are you?
/ Best drillbit for steel #30
<snip>
<snip>
When I would drill down into horizontal (flat) surfaces I tried to keep a small puddle of generic machine oil.
The last several times I had to drill I was drilling into vertical surfaces (like my trailer frame), thus the regular oil quickly ran away. That's when I decided to use QUALITY chain saw oil, because it was tacky and "stayed" better. I'd dip the bit in the oil and drill for maybe 10 seconds. No smoke.
/ Best drillbit for steel #31
/ Best drillbit for steel #32
1/4" pilot hole not too deep. Just a starter hole so I am centered correctly.
Thats why its taking so long.
Yep. Pilot hole needs to go all the way through unless you are using a split point bit.
A chisel tip without a pilot hole is not efficient. Cause that 1/4" tip doesnt have any cutting surfaces. You are more-or-less just eroding or chewing away that center portion. Without a BIG drill press where you can apply LOTS of pressure, a chisel tip needs a full pilot.
Even a 3/4" hole in 3/8" plate should take 20 seconds or so. Maybe less. Let me see....
200 rpm, with power feed on a drill press set at a generously slow .005" per revolution.... is 1" per minute.
So yea, shouldnt take but about 20 seconds if you are doing it right. Any longer and you are likely just burning up the bit.
/ Best drillbit for steel #33
I wouldn't use a hole saw for that small of a hole either but I have found if you are using large hole saws it works well to drill a 1/4" hole (a couple of drilling 3" or larger holes) just inside of but touching the cut line. It'll allow the oil to carry out the metal cuttings as it drains out of the 1/4" hole. Otherwise you'll need to remove the bit from the hole it's cutting and flush out the cuttings. A second tip for hole saws if not using a drill press is to cut the pilot hole first and then use a smooth 1/4" rod. Doing so will avoid the pilot bit catching on the side of the pilot hole and snapping off.
Like others have said, drill your pilot hole all the way through the material.
/ Best drillbit for steel #35
Yep I like this tip too, thanks!
/ Best drillbit for steel #36
I have had good luck with a drill doctor on 1/4 inch and above bits. Are they as good as new NO. Will they cut steel yes, and do a good job. If you you use them in a drill press I doubt you can tell they have been sharpened. I buy smaller bits in 10 pack from Amazon or Ebay.
I no longer want to buy a new drill bit set 1/8 to 1/2 every time I go to store. Trying to use up some of the 100s I have.
If I have a stainless steel project I do buy new dewalt bits.
I do not have the ability or training to sharpen on bench grinder as some have here. Oil and slow speed are your best bet.
I wish I had as good as luck with my DD with following the instructions religiously. I swear some of these come out of the factory "spot on" and other one's not so much.. I've never been able to sharpen any bit "as good as new" with my machine.
/ Best drillbit for steel #37
DrillDoctor to get both sides close then touchup by hand.
/ Best drillbit for steel #39
The dark cutting oil plumbers use for threading steel pipe keeps their threading dies sharp for a long time, and it will keep drill bits sharp for a long time too when used in mild steel. Enco has it in 1 gal and 5 gal containers for much less than the small bottles at the usual retail stores.
I keep the bit flooded with oil using a gravity feed arrangement on the drill press.
/ Best drillbit for steel #40
So back to my big question, how often do you guys lubricate the drill bit?
Depends on what I use.
Mill has mist lube, it keeps the bit cool.
Lathe has flood cooling.
Drill press or hand drill.....depends. The lube isnt so much to lube the bit. ITs to keep it cool and keep the chips from galling and sticking to the bit.
IF using a drill press, your holes should take ~20 seconds to drill each. One good application at the start of each hole should be sufficient.
If using a hand or mag drill, maybe once every 20-30 seconds. Depending on the type of fluid. There is some that is thin and runs away. Others are thick like honey and stay on the part/bit longer.
Clubcar Carry All 1700 (A64047)
Clubcar Carry All...
INOP/NON-RUNNING 2007 International 4400 Day Cab Truck, VIN # 1HSMKAZN77H451431 (A61165)
INOP/NON-RUNNING...
2016 KENWORTH T270 SERVICE TRUCK (A62130)
2016 KENWORTH T270...
2002 Suncoast 18ft T/A Enclosed Trailer (A61569)
2002 Suncoast 18ft...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
