Welding on empty drums
/ Welding on empty drums #2
My Dad said he saw a guy in the shop that wanted to make a burn barrel out of a 55 gallon sealed drum. As soon as he burned thru the end with the torch, Kaboom and he was dead. I think he said the drum has some kind of glue in it. Who knows what the glue solvent was, but something flammable. All it takes is just the fumes left in the barrel.
/ Welding on empty drums #3
That would have never happened if he used an Everlast welding machine! ;)
/ Welding on empty drums #4
If he had used a 120 volt MIG it would have never burn thru, because he would never have gotten any penetration.:laughing: I know I should never had said that but the devil made me do it.. :D
/ Welding on empty drums #5
Saw that happen at a place I worked 35 years ago. Mechanic in the shop took a empty 55 gal alchol drum (we burned alcohol in salamander heaters in the back of our delivery trucks in winter) and laid in on its side. He straddled the drum and started to cut the top out with the torch and kaboom! The end blew out and sent him flying out the shop door in flames. He had some serious burns and all the windows in the shop were blown out. Spent over a month at home recouperating before he came back to work. Company stopped using the alcohol heaters after that, we installed hot water baseboard in the trucks which was tied into the engine cooling system. We delivered plants and flowers year round to flower shops up and down the east coast.
/ Welding on empty drums #6
I take exception to the making fun about this type of situation. This sort of thing can happen whether using a 120v mig or a $20,000 three phase machine. I had a buddy get severely burnt from a metal 5 gal bucket blowing up. He wasnt even welding on the bucket, but using it for a seat while welding on something else. For my buddy, this was certainly a life changing event. I just pray that nobody reading this tread has a similar life changing, or life ending, experience.
/ Welding on empty drums #7
I don't think anyone was intentionally trying to make fun about it. NOBODY should ever weld or cut on barrel or have one in close proximity unless they know for sure what has been in it and/or it has been properly cleaned so it is not a dangerous hazard.
/ Welding on empty drums #8
Last time I wanted some holes in a barrel I used a pointed pickax. I have also shot holes in them. Of course the label on the ones I got from the feedstore said apple juice concentrate.
/ Welding on empty drums #9
I always use a jig saw. Used cold chisel & hammer for a long time but jig saw is quicker.
/ Welding on empty drums #10
An air chisel does a great job for this task. You will definitely want to use hearing protection.
/ Welding on empty drums #12
Well I have made many a burn barrel and never had one go boom.
Have used many techniques from a pick axe to core drills to make the vent holes with the core drill being the most efficient.
Usually I like 1 1/2" on a low rpm drill.
To cut off the tops a small axe and a bit of developed skill will make short job of decapping the drum.
Converting a 45 gal drum into a burn barrel is about a 45 min task.
/ Welding on empty drums #16
Barrels are not nice to work on unless they have been properly cleaned and that is not as easy to do as one would think.
True statement!! My dad was a power plant welder for his entire career. He would weld things that others would not touch. Never injured no close calls. One was gas tanks he would run water through the tank for hours sometimes overnight then weld it never a problem. Clean tank equals no flammable gas no problem.
/ Welding on empty drums #17
I've been told that after cleaning a drum that held a flammable product - fill it to the top with water and then remove the top. Since fumes in the drum are the major concern, the water fills the drum and there is no space for fumes.
/ Welding on empty drums #18
$30 gets a drum deheader on E-bay. Like a big can opener. Leaves a smooth edge too.
Not as smoth as you might think. There is still a sharp edge inside. Right where you might grab it.
But it's still the best way to open a drum.
213076 (A64276)
213076 (A64276)
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59912)
2025 ALCOM XPRESS...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2017 Peterbilt 320 T/A Heil 28Yd Front Loader Garbage Truck (A61573)
2017 Peterbilt 320...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
