Tooth bar for Kioti 72" bucket?
   / Tooth bar for Kioti 72" bucket? #21
Eric it looks good, what are your overall impression's so far of the tractor and the hitch for that matter.
I have zero impressions at this time because I haven't used the tractor for anything. The quick hitch is 140 pounds and readily fit onto my 3 pt (once I had the right size SpeeCo top pin). The NX has many, many hole combinations in the stabilizer bars and so I was able to center the Quick Hitch.
My tractor didn't come with a manual and so and I decided to stay in the city and study for the broker exam and sign up to take it next week. Unfortunately, my driveway was sealed today and if off limits for at least 24 hours. As a result, I'm not tearing into the tractor to begin installing things.
My biggest concern is where to mount the 3rd function valve and get the fittings all right. I plan to use a 16 gpm D03 valve and I need to determine the location so I know what sub plate to use. To do that the seat must come out and the tractor must be on my driveway.
Because of the missing owner's manual, I don't even know what size for type the quick disconnects are. Bummer.
   / Tooth bar for Kioti 72" bucket? #23
I believe they are ISO 7241-1 1/2 inch
There is an ISO 7241-1 A series and an ISO 7241-1 B series. if you happen to know, can you tell me what series A or B? Thanks.
   / Tooth bar for Kioti 72" bucket? #25
A series Eric. Also called 600series
2019 Ford F550 (A55973)
2019 Ford F550...
2018 John Deere 4066R (A53314)
2018 John Deere...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2007 Yard Dump Truck (A55973)
2007 Yard Dump...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
