110 TLB 3pt hitch question
/ 110 TLB 3pt hitch question #1
GreatWhitehunter
Eastern CT
JD 110 TLB
I'm about to purchase the 3pt hitch arms used and the seller tells me he believes they're off a 110.
Can some measure there 110 tlb hitch componets and post the specs? I'd hate to waste the money if they won't fit.
Thanks
Matt
/ 110 TLB 3pt hitch question #2
Are you looking for the hydraulic set # LVB25340(top n tilt) or the standard set # LVB24858
/ 110 TLB 3pt hitch question #3
The set that I have is 7/8'' thick 33'' long. JD # LVB24858
/ 110 TLB 3pt hitch question #4
The set Doc shows looks correct to me. If it were me I would try to get a set of telescopic arms instead from a 4000 series tractor. Way easier to hook up a clevis hitch box blade if you have the telescopic links. I fought with the standard hitch arms for four years and it was a chore to hook up the equipment by my self. The new telescopic arms made it easy to do.
/ 110 TLB 3pt hitch question #5
All of attachments that I have hooked up were light weight (), back blade 600 lbs, landscape rake 300 lbs. The box blade I"m going to hook up weights 1250. I can't move it by hand!!! I got a feeling I will be looking for a set of telescopic arms like you have.
Thanks so much Doc, I'm going the I match route again so hopefully the hook up won't be too much of an issue.
Matt:thumbsup:
Well, they turned out to be the correct 3pt hitch. I also picked up a grapple for the backhoe.
The hitch looks to be near unused and I go it for a fair $275.
Matt
/ 110 TLB 3pt hitch question #9
Have they got another one?
Unfortunately not, the seller purchased a lot of his neighbors implements during a divorce sale. These items from a 110 were of no use to the seller since he had a Kubota BX. He was unsure which tractor the hitch fit but I figured since the grapple was off of a 110 the hitch may have been also.
If I come across anymore at a reasonable price I'll shoot you a PM.
Matt
/ 110 TLB 3pt hitch question #11
Very nice of you...
It's one of those things that would open up a whole world of implements if I had one...
