La482 loader, problem raising
/ La482 loader, problem raising #1
bobgson
I bought a used 2002 kubota L3010 HST with 200 hours. The only problem is the loader valve lever has to be in the exact spot while pushing down or the bucket will not lift. All other functions on the valve work perfect and there is no play in the valve or lever. You have to push the lever down to the perfect spot and the bucket will go up ,if you push down farther the bucket stops and holds the height it's at and you can still push the valve down more till the lever stops. the bucket still stays in that position. This problem is the same loaded or empty. I had an old kubota and you could slam the valve in any position and it worked fine. This problem makes loading a truck a pain. Any help would be greatly appreciated.
/ La482 loader, problem raising #2
I'd think that an o-ring might be pinched to give you that problem but otherwise I haven't heard of it.
/ La482 loader, problem raising #3
Check and see if the screw in the end of the spool has backed off it will make the valve do strange things
/ La482 loader, problem raising #4
bobgson,
Mine did the same thing. Well, I sort of "forced the issue". Was bush hogging and turned around to watch the mower chew up a downed tree limb, when I turned back, the FEL had picked up a downed Hickory tree and bowed it about 8'. The instant I started backwards, the tree jumped the bucket and whapped the hood and slapped the steering wheel hard. No, I mean hard. The wheel tilted down and hit my thigh hard enough to give a bruise from hip to knee! I am pretty sure that it hitting the wheel saved me a half dozen busted ribs. Not a good thing to get!
But I digress, the solution was to take the valve cover box off and you will see adjustment screws. Ajdust the one that impacts the spool on the left (lift). The PIA is that you have to put it all back together to see how it's working, then take it apart and adjust some more and repeat. Took a few go rounds.
Good luck,
jb
took the end cover off the lifting valve and 5 balls ,one spring and a cup fell out. didn't see any adjusting screw,put it back the way i thought it came apart but doesn't have float mode now,probably cup in wrong. model of valve is L2205,serial 11495. thanks still need help.
/ La482 loader, problem raising #6
You probably need a Kit Detent, try to look here: http://www.tractorbynet.com/forums/kubota-owning-operating/88630-fel-goes-up-itself.html
I replaced myself the parts in the kit (75540-61420), and now my LA480 goes up and down, in full force. But I still have a problem with the bucket. It does not roll back, it only went to dump position, and I cannot make it to roll back. I believe the valve that sits next to the main control valve, is actually the valve controlling the bucket. It might have/need a kit too (probably the o-rings are the culprit). any ideas?
LA480 and LA482 are quite similar, if you need same pages from the workshop manual, for DIY repair, let me know.
/ La482 loader, problem raising #7
I have an la482 fel and am having trouble with the lever sticking. Was told this was because of the floating bucket which I don't understand. I would like to do away with this option as I can really see no use for it in my operations of the loader. I realize this is an old post and probably will get no reply, but would be interested in all feedback and possibly an exploded view of the control valve.
Just found my password and am able to post now. Had not been able for about 2 years. Thanks:confused2:
/ La482 loader, problem raising #8
Try lowering the 3PH a little.
I came across a Kabota last week that if the 3PH was all the way up the
loader would not work right.
I didn't have time to mess with it but could hear the hyd bypassing.
/ La482 loader, problem raising #9
Where is the lever sticking? If the float position, there is a detent, that keeps the bucket in float. If you don't want float, then don't select it, which is all the way fwd. You might try removing the cap off the spool with float, and check and clean the detent area. There are some balls and springs in there. Check for rust and other debris.
As far as passwords, you can also get another anytime.
/ La482 loader, problem raising #10
It was the float position. I finally got it free and am going to adjust the length of the linkage so that it won't go there again. There is a flip down bracket that I guess is supposed to keep it out of float, but the way it is adjusted now, when it is flipped down, the bucket won't go down. This is all new to me and I have learned more from this forum today than I have in a while. I really have no need for the float system, but I think I should still take the valve apart and clean it. I have copd and the medicine I take sometimes makes me very shaky. Will have to pick a good day for this I guess. Thanks to everybody for taking the time to answer. I think this is a great site and will visit it more regularly in the future. Thanks again everybody!!!!!!!!
/ La482 loader, problem raising #11
No matter how hard I try to avoid it, I still wind up stuck in float once in awhile.
Finally got around to removing the cap you told me about J J. There were 4 ball bearings (3 BB size and 1 almost twice as big). There were no springs or anything else. I left the balls out and seems to work fine. Do they have any other function other than the float? Thanks.
/ La482 loader, problem raising #12
I am not positive, but there should be springs in the float assembly, and the purpose is to keep the lever in the float position until you pull it back.
I believe if the springs are missing, you will not be able to keep the lever in float.
You might look at the manual for your valve and see if all the parts are there.
/ La482 loader, problem raising #13
Thanks J J. Exploded view shows 4 small balls and 1 larger ball with a spring. Evidently someone else has had cap off and spring and 1 small ball are missing. It seems to work great without those parts. I have no need for the float and am happy with the operation of the loader now. I was concerned it might affect some other operations of the bucket. All I have to do is move some dirt. Don't have to landscape it now. Will probably put machine up for sale next spring. Thanks a lot j_j.
/ La482 loader, problem raising #14
You need something to keep you out of float, or it could dump a load when you least expect it.
Going into float requires some effort if things are working right.
Enclosed Trailer with Lube System (A62613)
Enclosed Trailer...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
